Re: Programing on a network
I dont think there is a normal bootloader that can do that. But you can write your own and if you can add a ee2 to the board it would help. Then you load the hex into the ee2 and check that it is written correctly, reset the PIC and start the bootloader which will write the HEX from the ee2 to the flash.
Jumper, thanks for responding.
Well I’ve never written a bootloader before but I’m game. If I write my own bootloader I might as well write it to check the controller ID address, if it is the correct address continue bootloading as normal. I think that would be less complex than having the controller check ID address of incoming message then send a huge file to a ee afterwhich you pass to the bootloader.
Don’t you think the bootloader could be written to check ID then a function byte, then either load program or handle as a standard incoming message/data?
Wayne
