Last night, the azimuth on my dish was counting up 11541 to move the dish 180 deg. I changed NOTHING. I went to bed and came in this morning, and now it's only 3100. Now, in my code, I have it intentionally stepped down to only count every 10th pulse from the encoder, but I did not change it. I did this because on arduino, it was showing ~100,000 pulses @ 180 deg and the PIC I'm using doesn't support LONG.
It was doing this to me on the elevation randomly. Maybe it still is, it just isn't showing itself. The elevation should only be 3600+ counts full travel. That's what it was with an arduino 3 months ago when I started this project. Now it's 7200, but I tweaked that encoder's settings, so I can see that change. But sometimes, at random, it'll overflow a WORD 4 or 5 times @ full travel. That's a far cry from 3600 or 7200! And the kicker is, I do not think it's the encoder. When it would do this, I am watching it on a scope, and there would be zero change. Same PW and freq as it always has been.
PIC16F1829
Code:'****************************************************************
'* Name : UNTITLED.BAS *
'* Notice : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 6/7/2014 *
'* Version : 1.0 *
'* Notes : *
INCLUDE "DT_INTS-14.bas"
INCLUDE "ReEnterPBP.bas"
DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
APFCON0.2 = 1
APFCON0.7 = 1
OPTION_REG.6 = 1
__config _CONFIG1, _FOSC_HS & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF
__config _CONFIG2, _PLLEN_OFF & _LVP_OFF
DEFINE OSC 20
ANSELA = 0
ANSELB = 0
ANSELC = 0
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTA
DEFINE LCD_EBIT 1
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 1500
DEFINE LCD_DATAUS 44
LED var PORTC.7
high LED
INT_Handler INT_INT, _doEncoder, PBP, yes
@ INT_ENABLE INT_INT
stowlight var byte
stowlight = 1
TRISC.6 = 1
DOWN var PORTC.1
TRISC.1 = 0
DOWN = 0
EAST var PORTC.2
TRISC.2 = 0
EAST = 0
WEST var PORTC.5
TRISC.5 = 0
WEST = 0
UP var PORTC.0
TRISC.0 = 0
UP = 0
RX var PORTC.6
TRISC.6 = 1
a0 var byte
a1 var byte
e0 var byte
e1 var byte
i var byte
VerboseMode var byte
cereal var byte
Aencoder0Pos var word
Eencoder0Pos var word
HEL var byte
HAZ var byte
oldpos var word
newpos var word
distance var word
Eoldposition var word
Enewposition var word
stowed var byte
apple var byte
SatLocEl var word
SatLocEl = 6837
SatLocAz var word
SatLocAz = 52198
VerboseMode = 0
goto startup
doEncoder:
if UP = 1 then
' if e0 = 10 then
Eencoder0Pos = Eencoder0Pos + 1
' e0 = 0
lcdout $FE, $01, "EL= ", #Eencoder0Pos
lcdout $FE, $C0, "AZ= ", #Aencoder0Pos
' endif
' e0 = e0 + 1
if down = 1 then
' if e1 = 10 then
Eencoder0Pos = Eencoder0Pos - 1
' e1 = 0
' endif
e1 = e1 + 1
if EAST = 1 then
if a0 = 5 then
Aencoder0Pos = Aencoder0Pos - 1
A0 = 0
a0 = a0 + 1
if WEST = 1 then
if a1 = 5 then
Aencoder0Pos = Aencoder0Pos + 1
a1 = 0
a1 = a1 + 1
@ INT_RETURN
Startup:
gosub CLR
hserout ["Running Startup Procedures!", 13, 10]
hserout ["PLEASE WAIT....", 13, 10]
pause 3000
Eencoder0Pos = 0
Eoldposition = Eencoder0Pos
DOWN = 1
gosub allSTOP
Enewposition = Eencoder0Pos
IF Eoldposition = Enewposition THEN
stowed = 1
apple = 1
Eencoder0Pos = 0
Aencoder0Pos = 40000
gosub CLR
hserout ["Startup Sequence Good!", 13, 10]
hserout ["Continuing to Main Menu...", 13, 10]
pause 5000
goto MainMenu
IF Enewposition <> Eoldposition THEN
stowed = 0
apple = 1
UP = 1
gosub allSTOP
gosub CLR
hserout ["Startup Error!", 13, 10]
hserout ["Dish will need homing before move will be allowed!", 13, 10]
pause 5000
goto Mainmenu
MainMenu:
gosub CLR
HSEROUT ["******** MAIN MENU ********", 13, 10, 10]
HSEROUT [" 1. Start Homing Sequence", 13, 10]
HSEROUT [" 2. Manual JOG Mode", 13, 10]
HSEROUT [" 3. Auto-Acquire Satellite", 13, 10]
HSEROUT [" 4. Stow Dish for Travel", 13, 10, 10]
HSEROUT ["Enter Your Selection:",13,10]
SERIN RX, 2, cereal
if VerboseMode = 1 then HSEROUT [#cereal,13,10]
If cereal = "1" then goto HomeDish
If cereal = "2" then
if apple = 1 then goto JogMenu
if apple <> 1 then gosub ForceHome
If cereal = "3" then
if apple = 1 then goto RoughAcquire
If cereal = "4" then
if apple = 1 then goto StowMenu
goto MainMenu
RoughAcquire:
if Eencoder0Pos < 7000 then
UP = 1
uploop1:
if Eencoder0Pos < 7000 then goto uploop1
gosub allSTOP
If Aencoder0Pos < SatLocAz then
WEST = 1
azloop1:
if Aencoder0Pos < SatLocAz then goto azloop1
gosub allSTOP
elseif Aencoder0Pos > SatLocAz then
EAST = 1
azloop2:
if Aencoder0Pos > SatLocAz then goto azloop2
gosub allSTOP
If Eencoder0Pos > SatLocEl then
DOWN = 1
dnloop1:
if Eencoder0Pos > SatLocEl then goto dnloop1
gosub allSTOP
goto MainMenu
HomeDish:
gosub CLR
hserout ["******** HOME DISH ********", 13, 10, 10]
hserout [" 1. Start Homing Sequence", 13, 10, 10]
hserout [" 2 Abort Homing", 13, 10, 10]
hserout ["Enter Your Selection:"]
serin RX, 2, cereal
if cereal = "2" then goto MainMenu
homeloop:
IF cereal = "1" THEN
HAZ = 0
HEL = 0
gosub HomeEL
gosub HomeAZ
'Haz = 1
IF (HEL = 1) AND (HAZ = 1) THEN
gosub clr
hserout ["HOME PROCESS WAS SUCCESSFUL!", 13, 10]
apple = 1
goto MainMenu
IF (HEL = 0) OR (HAZ = 0 ) THEN
gosub clr
hserout ["DIS HOME PROCESS CAN SUCK MY DICK!", 13, 10]
goto MainMenu
pause(200)
if cereal <> "1" then goto HomeDish
goto homeloop
goto HomeDish
HomeAZ:
gosub clr
hserout ["HOMING AZIMUTH - PLEASE WAIT..", 13, 10]
PAUSE(500)
Aencoder0Pos = 0
oldpos = 0
WEST = 1
PAUSE(250)
IF Aencoder0Pos = 0 THEN
gosub allSTOP
EAST = 1
PAUSE(250)
gosub allSTOP
PAUSE(500)
Aencoder0Pos = 0
WEST = 1
PAUSE(500)
IF Aencoder0Pos = 0 THEN goto moveerror
loop4:
pause 250
oldpos = newpos
newpos = Aencoder0POS
if oldpos > newpos then
distance = oldpos - newpos
hserout ["oldpos = ", #oldpos, " newpos = ", #newpos, " --- Distance = ", #distance, 13, 10]
if newpos > oldpos then
distance = newpos - oldpos
hserout ["newpos = ", #newpos, " oldpos = ", #oldpos, " --- Distance = ", #distance, 13, 10]
if (oldpos = newpos) and (oldpos <> 0) then distance = 0
if (distance < 5) or (distance > 500) then
gosub allSTOP
Aencoder0Pos = 54000
hserout ["HOMING AZIMUTH WAS SUCCESSFUL!", 13, 10]
HAZ = 1
IF HAZ = 0 THEN goto loop4
EAST = 1
loop8:
hserout ["Aencoder0Pos = ", #Aencoder0Pos, 13, 10]
if Aencoder0Pos > 50000 then GOTO LOOP8
GOSUB allSTOP
HomeEL:
gosub CLR
hserout ["HOMING ELEVATION - PLEASE WAIT..", 13, 10]
PAUSE(500)
Eencoder0Pos = 0
UP = 1
PAUSE(250)
IF Eencoder0Pos = 0 THEN
gosub allSTOP
DOWN = 1
PAUSE(250)
gosub allSTOP
PAUSE(500)
Eencoder0Pos = 0
UP = 1
PAUSE(500)
IF Eencoder0Pos = 0 THEN goto moveerror
loop1:
pause 250
oldpos = newpos
newpos = Eencoder0POS
if oldpos > newpos then distance = oldpos - newpos
if newpos > oldpos then distance = newpos - oldpos
if oldpos = newpos then distance = 0
if distance < 5 then
gosub allSTOP
Eencoder0Pos = 7220
hserout ["HOMING ELEVATION WAS SUCCESSFUL!", 13, 10]
HEL = 1
IF HEL = 0 THEN goto loop1
DOWN = 1
loop2:
'hserout ["Eencoder0Pos = ", #Eencoder0Pos, 13, 10]
if Eencoder0Pos > 7000 then GOTO loop2
oldpos = 0
newpos = 0
GOSUB allSTOP
StowMenu:
gosub CLR
hserout ["******** STOW DISH ********", 13, 10, 10]
hserout [" 1. Start STOW Sequence", 13, 10, 10]
hserout [" 2 Abort STOW", 13, 10, 10]
serin RX, 2, cereal
if (cereal = "1") and (apple = 1) and (stowed <> 1) then goto StowDish
goto moveerror
StowDish:
gosub CLR
hserout ["***** PLEASE WAIT ******", 13, 10]
if Eencoder0Pos < 5500 then
UP = 1
loop3:
pause 250
if Eencoder0Pos < 5500 then goto loop3
gosub allSTOP
If Aencoder0Pos > 40000 then
east = 1
loop5:
pause 250
if Aencoder0Pos > 40000 then goto loop5
gosub allSTOP
elseif Aencoder0Pos < 40000 then
WEST = 1
loop6:
pause 250
if Aencoder0Pos < 40000 then goto loop6
gosub allSTOP
If stowlight = 1 then
down = 1
loop7:
pause 250
oldpos = newpos
if (Eencoder0Pos > 0) and (distance <> 0) then goto loop7
gosub allSTOP
elseif stowlight <> 1 then
gosub moveerror
gosub forcehome
apple = 0
goto mainmenu
JogMenu:
gosub CLR
pause 250
HSEROUT ["***** JOG MENU *****", 13, 10, 10]
HSEROUT ["U - UP", 13, 10]
HSEROUT ["D - DOWN", 13, 10]
HSEROUT ["E - EAST", 13, 10]
HSEROUT ["W - WEST", 13, 10]
HSEROUT ["S - ALL STOP", 13, 10]
HSEROUT ["X - MAIN MENU", 13, 10, 10]
SERIN RX, 2, cereal
IF cereal = "A" then Eencoder0Pos = 0
if cereal = "B" then Aencoder0Pos = 0
if cereal = "U" Then
gosub allSTOP
UP = 1
if cereal = "D" then
gosub allSTOP
DOWN = 1
if cereal = "E" then
gosub allSTOP
EAST = 1
if cereal = "W" then
gosub allSTOP
WEST = 1
if cereal = "S" then gosub allSTOP
if cereal = "X" then
gosub allSTOP
goto MainMenu
goto JOGMenu
allSTOP:
EAST = 0
UP = 0
DOWN = 0
WEST = 0
if VerboseMode = 1 then GOSUB POS
CLR:
if VerboseMode = 0 then
For i = 0 to 30
HSEROUT [10]
next i
abort:
gosub allSTOP
gosub clr
HSEROUT ["USER STOP! -- MOVE ABORTED!", 13, 10]
PAUSE(5000)
goto MainMenu
ForceHome:
gosub CLR
hserout ["SYSTEM ERROR!", 13, 10]
hserout ["SYSTEM'S HOMING COORDINATES NOT SET!", 13, 10]
hserout ["SYSTEM CANNOT BE MOVED UNTIL HOMING IS PERFORMED!", 13, 10]
pause 7000
moveerror:
gosub allSTOP
gosub clr
HSEROUT ["SYSTEM ERROR! -- MOVE ABORTED!", 13, 10]
PAUSE(5000)
goto MainMenu
POS:
