Hi there!
I have zero knowledge of assembly code. I got this from a website for an IR Remote Control. I used the supplied HEX file to program a 16F684 to success. My application requires I hold down the momentary buttons to perform Volume + and Volume - operations. However, when I use the code, it only transmits for a few seconds. I have to release then re-press the button. Is there anyone who understand assembly how can alter the code to allow continuous pressing of the buttons?
I am using the 8 channel mode.
Thanks for your help!
Here's the code:
Code:list p=16f684
__CONFIG _CP_OFF & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _INTRC_OSC_NOCLKOUT & _BOD_OFF & _FCMEN_OFF & _IESO_OFF
; toggle or momentary mode, 8 channels
#define MODE_CH8
; ON/OFF latched mode, 4 channels
;define MODE_CH4
#include <p16F684.inc>
#include <irmtxv4.inc>
variables UDATA
; RAM registers
tcnt RES 1
rcnt RES 1
cod RES 1
prevcod RES 1
cod0 RES 1
rowstate RES 1
startup CODE 0
nop
nop
nop
retfie
prog CODE
main ; program starts here
movlw 7
movwf CMCON0 ; set outputs digital
BANKSEL ANSEL
clrf ANSEL
movlw 0x17
movwf TRISA
clrf TRISC
movwf WPUA
movwf IOCA
clrf TMR0
bcf OPTION_REG, PSA
clrwdt
movlw (0<<NOT_RAPU)|(0<<T0CS)|(0<<INTEDG)|(0<<PSA)|(0x07)
movwf OPTION_REG ; portA pullups enabled
clrwdt
BANKSEL PORTA
clrf PORTA
clrf PORTC
movlw (1<<RAIE); RA int on change enable
movwf INTCON
call mtx_init
clrf mtx_buffer
clrf tcnt
loop0 clrf (mtx_buffer+1)
movlw 0xff
movwf prevcod ; no button was pressed in the previous scan
movlw 0x1c ;c0,c1=0,c3=1
movwf PORTC
movlw 0x00
tris PORTC
movf PORTA, W
bcf INTCON, RAIF
sleep
loop clrf cod
movlw 0x1d
tris PORTC ; select colA (RC1)
clrf PORTC
#ifdef MODE_CH8
clrw
#endif
#ifdef MODE_CH4
movlw 0x20
#endif
call scan
movlw 0x1e
tris PORTC ; select colB (RC0)
#ifdef MODE_CH8
movlw 0x04
#endif
#ifdef MODE_CH4
movlw 0x30
#endif
call scan
movf cod, W
bz loop2 ; if no buton is pressed, skip
subwf prevcod, W ; if the same button is pressed, skip
bz loop2
movf cod, W
movwf prevcod ; a new button is pressed - rcnt=3
movwf (mtx_buffer+1)
movlw 3
movwf rcnt
movlw 0x40 ; new button - new transmission
addwf tcnt, F
loop2 movlw 0x17
tris PORTC ; select ID (RC3)
call scanid
movf cod0, W
movwf (mtx_buffer)
loop3 movf (mtx_buffer+1), W
andlw 0x3f
iorwf tcnt, W
call mtx_send
movf rcnt, W
bz loop_done
decfsz rcnt, F
goto loop
loop_done movf cod, W
btfsc STATUS, Z
goto loop0 ; no button was pressed, go sleep
; if the same button is being hold, repeat the transmission
goto loop
scan movwf cod0
;movlw 0xc0
scandelay ;addlw 1
;bnz scandelay
movlw 0x17
andwf PORTA, W
movwf rowstate
incf cod0, F
btfss rowstate, 2
goto pressed
incf cod0, F
btfss rowstate, 4
goto pressed
incf cod0, F
btfss rowstate, 0
goto pressed
incf cod0, F
btfss rowstate, 1
goto pressed
retlw 0
pressed movf cod0, W
movwf cod
scanid clrf cod0
clrw
scandelay2 addlw 1
bnz scandelay2
movlw 0x17
andwf PORTA, W
movwf rowstate
btfss rowstate, 4
bsf cod0, 3
btfss rowstate, 0
bsf cod0, 2
btfss rowstate, 2
bsf cod0, 1
btfss rowstate, 1
bsf cod0, 0
