Can't get the simplest of programs to run using internal osc and just toggling a pin
Here is the code. It will not toggle the pin. I have to be missing something painfully obvious. I am hoping somebody will spot it immediately and while making me feel dumb, save me another 17 days of head banging. It started on a circuit board but I have moved it to a breadboard with nothing but 2 "AA" batteries powering the PIC and checking the pins with a multi-meter. Thanks.
__config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _IOSCFS_4MHZ & _CP_OFF & _PWRTE_OFF & _IOSCFS_4MHZ & _BOR_OFF
include "alldigital.pbp"
trisio.5 = 0
trisio.0 = 0
do
'serout2 gpio.5, 396, ["M"]
high 0
low 0
loop
Re: Can't get the simplest of programs to run using internal osc and just toggling a
Sorry. I should have put the PIC in. It is a 12HV615. I have Darrel's ALLDIGITAL file in the same folder as the project folder and everything compiles and acts normally. I have also tried more than one of the same PIC but don't have a different model 8 pin PIC to try.
Hello,
What pic chip are you using?
You may have to set the oscon register to make the internal oscillator function.
Also your "high 0" and "low 0" statements should be changed to High gpio.0 and Low gpio.0
Ok, I see that the pic12hv614 has no oscon register and is done in the configuration
I have tried doing gpio.0 as well with no better result. This cut and paste is just the latest thing I have tried out of desperation. Not that it is right but I have numerous other programs that I just us "High 4" and it works. Thank you for your time in looking at this.
When you compile, does ALLDIGITAL suggest lines to be added to your code?
No, it didn't. Nothing was out of the ordinary as far as I could tell. It didn't before I added the alldigital file to the folder but I did it anyway just in case. I am completely baffled.
See if this will work.
DEFINE OSC 4 ' keep above your code and registers settings
Adcon0 = 0 'disable adc
ANSEL = 0 'gpio all digital
TRISIO = 0 'all outputs except gpio3
do
high 0
low 0
loop
Yes, I forgot the High/Low 0 statements are from the old Basic Stamp days.
No dice. I have tried yet another PIC to make sure I didn't damage the last two and tried a different programmer in the event that was damaged (1 in a million, I know). My gut is that I am missing something oscillator related but cannot figure out what. Thanks for the look at what I have.
Do you have !MCLR tied high? I see it disabled in the config, but it's worth a try.
I found an issue and correcting it seems to correct the issue. However, I am left a little confused as to what is going on. I am using MC Studio 5.0.0.5 with Melabs programmer v4.51 on a computer running Windows 8.1. Everything appears to program fine but the PIC doesn't work. I tried using my netbook which I typically only use when on a job site to compile and program the same code and it works fine (MC studio 5.0.0.0 and programmer 4.32 and Windows 7 starter). I don't know if it is MC studio that is causing the problem or the programmer software but there appears to be some issue. Unfortunately, I don't have time to look into it right now because I am a day and a half behind because of this issue. Thank you all for your help.
