Struggling again with SEROUT2 and numbers format
Hello all,
I think I need your help to resolve this.
I have a radio that accepts commands via its serial port.
My project is to remote control it (wireless or infrared) to change memories, volume, etc...
Until now everything is OK so I'm posting only the program part I have stucked.
With the following subroutine I want to increase the volume.
So, first I want to read the current volume setting and then add 10 to increase the volume by ten units.
But the radio is not accepting that command (and only that command).
I think the problem is with the number format of the variables i use.
As you can see from the code, the volume (and most other radio settings) has values from 0 - 254.
For some unknown to me reason, the radio uses 2 bytes for theses values and not one.
So, first byte gets values from 0 - 2 and second byte gets values from 0-99.
To display them correctly to my serial LCD i use the HEX modifier and the appear OK as I manualy (not remotely) change the volume.
At the end of the program I have entered some commands (for testing) to change the volume and they work fine !
But when I place the variables in the SEROUT2 command nothing happens and the volume remains at the same level.
What am I doing wrong ? Do you see something that needs to be changed for this thing to work ?
' VOLUME UP SUBROUTINE
VOLUP: ' All variables are set as bytes
' Volume in range 000 - 254
' f1 values are 00,01,02
' f2 values are 00 - 99
SEROUT2 CIVP,CIVS,[$FE,$FE,CIVA,$E0,$14,$01,$FD] ' Send this to the radio to read Audio SETTING - WORKS !!!
SERIN2 CIVP,CIVS,[SKIP 6,f1,f2] ' Skip first 6 useless bytes and read next 2 volume bytes - WORKS !!!
' The next 4 lines are only for testing and to display a total volume value (000-254) to LCD in decimal
x1 = f1 & %00001111 ' read units - WORKS !!!
x2 = f2 >> 4 ' divide / 2^4 = 16 (tens) - WORKS !!!
x3 = f2 & %00001111 ' read units - WORKS !!!
Z = x1 * 100 + x2 * 10 + x3 ' a number between 0 - 254
f3 = f1 ' Same value for testing purposes only
f4 = f2 + 10 ' Increase volume by 10 units - This is what I want to do
pause 50 ' Give some time to radio to recover from SERIN2
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,$f3,$f4,$FD] ' Send this to the radio for NEW VOLUME setting - NOT WORKING :(
'SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,f3,f4,$FD] ' Send this to the radio for NEW VOLUME setting (no $) - NOT WORKING :(
serout2 lcdp,lcds,[i,line1," DEC : ", DEC3 Z,"-",DEC2 f3, DEC2 f4] ' Just print to serial LCD for debugging - It's correct + 10
serout2 lcdp,lcds,[i,line2," HEX : ", DEC3 Z,"-",HEX2 f1, HEX2 f2] ' Just print to serial LCD for debugging - It's correct
pause 50 ' Give some time to radio to recover from SEROUT2
' The following 3 lines are only for testing purposes - they all work OK !!!!!!!!!!!!
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,$00,$00,$FD] ' Mute, no sound, Z = 0 - WORKS OK !!!
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,$01,$28,$FD] ' 50% volume, Z = 128 - WORKS OK !!!
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,$02,$54,$FD] ' 100% volume, Z = 254 - WORKS OK !!!
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,$00,$00,$FD] ' Mute again - my ears !!! - WORKS OK !!!
RETURN ' Go back to main routine to check for another button press
Thanx in advance
Fanias
Re: Struggling again with SEROUT2 and numbers format
Hi Fanias,
Just a guess on my part
CIVA is uppercase
civa is lowercase
I am GUESSING, since I do not know what the radio does but uppercase and lowercase letters are different numbers as all characters are numbers . . .
also same for F vs f
Nah, I don't think that's it...
CIVA must be a variable and they are not case sensitive. Had it been a string it should have been "CIVA" vs "civa"
As a test, ditch the calculations and try:
f3 = $01
f4 = $28
In this particular case you do not want the $-sign because then it'll send the hexadecimal numbers F3 and F4 and not the content of the variables f3 and f4. Having the $-sign in there would have made the above statement send 243 ($f3), 244 ($f4) instead of 1 ($01), 40 ($28).
Thank you both for your time and answers.
I think I found a solution, not sure why is this happening but works...
I tread the numbers I read from radio as BCD, I convert them to binary, increase the volume by adding 10, convert them to BCD again and finally send them to the radio.
I'm sure there must be an easier way to do this, because I can send other settings very easy.
The civa is just a constant (address of the radio) and is civa = $70, the same as CIVA = $70.
Here is the working code for your information, maybe you can help me to make it simpler without all these calculations.
VOLUP1:
x1 = f1 & 001111 ' read units - WORKS !!!
x3 = f2 & 001111 ' read units - WORKS !!!
f3 = ((f1 >> 4) * 10) + (f1 & $0f) ' Convert BCD to binary
f4 = ((f2 >> 4) * 10) + (f2 & $0f) ' Convert BCD to binary
f4 = f4 + 10 ' Increase volume by 10 units - This is what I want to do
IF f4 > 99 THEN
f4 = 0 ' Make sure result is less than 100
f3 = f3 + 1
IF f3 > 1 AND f4 > 54 THEN ' If volume > 254 go back to volume 0
f3 = 0
f4 = 0
f5 = ((f3 / 10) << 4) + (f3 // 10) ' Convert bin to BCD
f6 = ((f4 / 10) << 4) + (f4 // 10) ' Convert bin to BCD
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,f5,f6,$FD] ' Send this to the radio for NEW VOLUME setting - THIS WORKS NOW :)
Thanx again
Fanias
Now PIC hangs after 14 times of a subroutine execution
Hello again,
after solving my problems with serial port, I found that PIC (18F46K22) hangs after I send a command 14 times exactly.
I'm using some code I found in the forum to remote control via the NEC infrared protocol a receiver.
It works but when I press quickly 14 times the Volume UP button (to increase volume) the PIC hangs and a reset is needed.
Three questions for anyone who wants to help.
- I can't increase the Oscillator speed (e.x. το 16 MHz) to get the higher serial port speeds I need, the code works only at 4 MHz.
I realize that the values of DL1 and DL2 must be icreased, but they don't work for DL1 = 3200 and DL2 = 440 (for 16 MHz), so I'm stuck to 4 MHz
- The program hangs PIC when I call quickly 14 times the VOLUP subroutine. What is wrong in this subroutine ? I have also implemented a basic repeat function (VOL+ button always pressed which works)
- How can I enable a feature or a function like WDT to avoid this hang when it occurs ? As you can see in the top of the program I tried to enable the WDT and tried different prescale values but nothing happens. Can you help with that in case I cannot fix the hang ?
Here is the complete program :
'==================================== CONFIGURE PIC ===========================================
' # 18F46K22 #
DEFINE PULSIN_MAX 10000
@ CONFIG PBADEN = OFF ' PORTB<5:0> pins are configured as digital I/O on Reset
@ CONFIG LVP = OFF ' Single-Supply ICSP disabled
@ CONFIG XINST = OFF ' Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
'@ CONFIG STVREN = ON ' Stack full/underflow will cause Reset
'@ CONFIG WDTEN = ON ' WDT is always enabled. SWDTEN bit has no effect
'@ CONFIG WDTPS = 512 ' Watchdog Timer Postscale Select bits
'@ CONFIG PWRTEN = ON ' Power up timer enabled
'@ CONFIG BOREN = SBORDIS ' Brown-out Reset enabled in hardware only (SBOREN is disabled)
'@ CONFIG BORV = 285 ' VBOR set to 2.85 V nominal
@ CONFIG FOSC = INTIO67 'Internal oscillator block
OSCCON.6 = 1 '#################### 111 = 16, 110 = 8
OSCCON.5 = 0 '###### 16 MHz ###### 101 = 4, 100 = 2
OSCCON.4 = 1 '####################
OSCTUNE.6 = 0 '##### PLL X 4 ######
'@ CONFIG PLLCFG = ON 'Oscillator multiplied by 4
'####### Make Ports Digital ##########
ANSELA = $00 'SET PORT A ALL DIGITAL
ANSELB = $00 'SET PORT B ALL DIGITAL
ANSELC = $00 'SET PORT C ALL DIGITAL
ANSELD = $00 'SET PORT D ALL DIGITAL
ANSELE = $00 'SET PORT E ALL DIGITAL
'=================================== INCLUDE FILES ==========================================
'=================================== SET PIC PORTS ==========================================
HCDATA var PORTC.5 ' Pin 14 74HC595
HCCLK var PORTD.4 ' Pin 11 74HC595
HCLAT var PORTC.7 ' Pin 12 74HC595
CIVP VAR PORTA.5 ' TO ICOM REMOTE PORT CI-V
LCDP VAR PORTB.0 ' SERIAL LCD PORT (OPTIONAL)
INFRA VAR PORTD.7 ' Infrared LED DATA
'LED VAR PORTC.0 ' STATUS LED
'==================================== SET VARIABLES =========================================
Leader VAR WORD ' will be up to 900 for a 9mS leader pulse
BtnVal VAR BYTE[32] ' holds 32 pulse results
DByte1 VAR BYTE ' address byte
DByte2 VAR BYTE ' inverse of address byte
DByte3 VAR BYTE ' command byte
DByte4 VAR BYTE ' inverse of command byte
X VAR BYTE ' loop count
Y VAR BYTE ' = DByte3 (command) for subroutines selection
Z VAR BYTE ' Generic counter FOR-NEXT Loops (digits counter)
RBdata VAR BYTE[6] ' Bytes array to store digits for frequency or memory
f1 VAR BYTE ' Vol, SQL, MSB byte
f2 VAR BYTE ' Vol, SQL, LSB Byte
f3 VAR BYTE ' BCD to BIN byte store for DEC calculations
f4 VAR BYTE ' BCD to BIN byte store for DEC calculations
pattern VAR Byte ' 74HC595 output pattern
'===================================== SET CONSTANTS =======================================
DL1 CON 800 ' > 8.5 ms pulse for NEC Protocol (Start) - 850 @ 4 MHz
DL2 CON 110 ' > 1.5 ms pulse for NEC Protocol (read bit 0 or 1) @ 4 MHX
LCDS CON 16468 ' SERIAL LCD SPEED 16468 -> 9600
LINE1 CON 128 ' LCD Line 1
LINE2 CON 192 ' LCD Line 2
I CON 254 ' LCD general command
CIVS CON 84 ' "188"->4800, "84"->9600, "32"->19200 "813"->1200
CIVA CON $70 ' TRX address
'################################# PROGRAM STARTS HERE #####################################
START:
CLEAR '
pattern = %00000000 ' LED OFF
gosub OUT_595
PAUSE 200
GOSUB LCDCLS
PAUSE 10
SEROUT2 LCDP,LCDS,["HELLO MALAKA"]
pattern = %11111111 ' LED ON
gosub OUT_595
gosub OUT_595
gosub LCDCLS ' Clear LCD
'============================== MAIN LOOP CHECKS FOR INFRARED COMMAND =========================
MAIN:
PULSIN INFRA,0,Leader ' Leader pulse is ~9mS low-going
IF Leader < DL1 THEN Main ' Valid start burst check > 8.5 ms
GOSUB READ32 ' Read 32 bytes (0-15 for address and 16-31 for command)
'GOTO MAIN ' ONLY FOR TESTING AND READING VARIOUS NEC REMOTES
GOSUB COMMANDS ' GOTO Check Input Commands
PAUSE 100
GOTO MAIN
'=================================== VOLUME UP SUBROUTINE ====================================
Z = $01 ' For future functions
DO
IF Leader > DL1 THEN
GOSUB VOLUP1 ' Go to increase volume
pattern = 0
GOSUB Out_595
GOTO MAIN
PULSIN INFRA,0,Leader ' Check again for start pulse (autorepeat function) WORKS
LOOP
GOTO VOLUP ' Go back to main routine to check for another button press
'================================ VOLUME INCREASE AND BYTE CALCULATIONS =======================
VOLUP1:
GOSUB READVD
IF f3 < 2 AND f4 >= 99 THEN
f3 = f3 + 1 ' Increase hundreds by 1
ELSEIF f3 > 1 AND f4 > 54 THEN ' If volume > 254 stay to 254 (max)
f3 = 2
f4 = 54
f1 = ((f3 / 10) << 4) + (f3 // 10) ' Convert bin to BCD
f2 = ((f4 / 10) << 4) + (f4 // 10) ' Convert bin to BCD
SEROUT2 CIVP,CIVS,[$FE,$FE,civa,$E0,$14,$01,f1,f2,$FD] ' NEW VOLUME setting
pause 50
'GOSUB PRINTVAL ' Only for testing and displaying actual volume
'===================================== RECEIVED COMMANDS ====================================
COMMANDS:
Y = DByte3
IF Y = 7 OR Y = 3 THEN ' VOL - (added new NEC remote)
pattern = 1
GOSUB Out_595
' GOSUB VOLDOWN
IF Y = 21 OR Y = 2 THEN ' VOL + (added new NEC remote)
pattern = 1
GOSUB Out_595
GOSUB VOLUP
'######################################################## CLEAR LCD #########################################################
LCDCLS:
SEROUT2 LCDP,LCDS,[254,1] ' Clear LCD
Out_595:
SHIFTOUT HCDATA,HCCLK,1,[pattern] ' send pattern to 1st 74HC595
PULSOUT HCLAT, 5 ' latch outputs
'================================ READ 32 Bytes - Address and Command =========================
READ32:
FOR X = 0 TO 31 ' grab 32 incoming pulses
PULSIN INFRA,1,BtnVal[X] ' now measuring high-going pulse widths
NEXT X
FOR X = 0 TO 7 ' sort 1st 8 pulses
IF BtnVal[X] > DL2 THEN ' > 150 x 10uS = > 1.5mS pulse period
DByte1.0[X]=1
DByte1.0[X]=0
NEXT X
FOR X = 8 TO 15 ' sort 2nd 8 pulses, etc....
DByte2.0[X-8]=1
DByte2.0[X-8]=0
NEXT X
FOR X = 16 TO 23
DByte3.0[X-16]=1
DByte3.0[X-16]=0
NEXT X
FOR X = 24 TO 31
DByte4.0[X-24]=1
DByte4.0[X-24]=0
NEXT X
DByte4 = ~ DByte4 ' Reverse all the 8 bits to compare
IF DByte3 <> DByte4 THEN
GOSUB LCDCLS
SEROUT2 LCDP,LCDS, [I,LINE1,"Command ERROR !"]
GOSUB LCDCLS
pattern = 0
GOSUB out_595
GOTO MAIN
SEROUT2 LCDP,LCDS, [I,LINE1,"A : ",DEC3 DByte1, "-",BIN8 DByte1] ' PRINT ADDRESS
SEROUT2 LCDP,LCDS, [I,LINE2,"C : ",DEC3 DByte3, "-",BIN8 DByte3] ' PRINT COMMAND
'================================== Read Volume & SQL Data ====================================
READVD:
SEROUT2 CIVP,CIVS,[$FE,$FE,CIVA,$E0,$14,Z,$FD] ' Send this to the radio to read current SETTING
SERIN2 CIVP,CIVS,[SKIP 6,f1,f2] ' Skip first 6 useless bytes and read next 2 bytes
PAUSE 5 ' Give sometime to rest
RETURN ' Go back to set new Volume or Squelch
Well, that's all folks...
Thanx in advance
Fanias
for one
your volup: subroutine
has a goto main in it , this will eat up the stack , pic18 subs can only nest 22 levels deep at the most
subroutines aren't re-entrant and must return to where they called from .
DO
pattern = 0
GOSUB Out_595
GOTO MAIN
LOOP
VOLUP1:
richard
for one
DO
pattern = 0
GOSUB Out_595
GOTO MAIN
LOOP
VOLUP1:
OMG !!!
Thank you Richard, I couldn't see the obvious !!!
I feel I have to post the solution you provided and I ended up with a smaller code that does the same.
VOLUP: '
Z = $01 ' Volume sub command
DO WHILE Leader > DL1 ' If START pulse increase volume
GOSUB VOLUP1
PULSIN INFRA,0,Leader ' Check for another for auto repeat
LOOP
pattern = 0 ' LED OFF
GOSUB out_595
RETURN ' Go Back to Commands and then Main
Now I have to fight with the PULSIN command @ 16 MHz.
If someone asks why to go @ 16 MHz if 4 Mhz works OK, the answer is that I need higher serial port speeds.
@ 4 MHz I use DL1 = 800 and DL2 = 110
so @ 16 MHz I have to use DL1 = 3200 and DL2 = 440.
but the above values are not working. I'm sure I'm missing something, I wonder what is it :-)
I don't think is a hardware problem, the HX1838 infrared receiver is connected to PORTD.7 and a pullup resistor of 10K is also used.
I tried also without the pullup and the results are the same and tried to move ports but no luck.
Thanx
Fanias
That would do it 'cause I use that PIC at highest internal osc setting and it works great.
VOLUP should exit with a RETURN. Also, READ32 should not have a GOTO MAIN in it as well.
from the manual :-
The resolution of PULSIN is dependent upon the oscillator frequency. If a 4MHz oscillator is used, the pulse width is returned in 10us increments. If a 20MHz oscillator is used, the pulse width will have a 2us resolution. Defining an OSC value has no effect on PULSIN. The resolution always changes with the actual oscillator speed.
more info
@16 MHz that's 2.5uS units
8.5mS =3400 ,1.5mS =600
richard
from the manual :-
more info
Thank you both for your usefull comments.
@ Richard,
you are correct, I've done my self calculations and we are the same.
The problem must be somewhere else or at PIC configuration (maybe ??)
Since I don't have any other way to see what happens here, I'm simply printing on LCD the values I'm reading with the PULSIN command.
My results are correct @4 MHz but wrong at 16 MHz.
@4 MHz I get for "Start" pulse, "0" pulse and "1" pulse respectively : 898, 56, 168. These results are correct according to the NEC protocol (for ex. 898 * 10 us ~ 9 ms which is fine for the start pulse).
But @ 16 MHz I get : 3600, 229, 129.
The 3600 result is correct (~ 898 * 4),
The 229 result is also correct (~ 56 * 4),
BUT 128 is wrong and should be ~ 168 * 4 = 672 !!!
So here is my problem, I can read @16 MHz the "Start" pulse and "0" pulse, but the "1" pulse is wrong, it's way LOWER value than it should be.
What do you think about this ?
does it really matter why not call it a "0" if < 180 or a "1" if > than 180
what are you using for ir receiver , could it be noise or the "carrier wave" slipping through
how good is your power supply ,is everything bypass capped properly ?
I'm not sure which is what here but I see only one WORD variable (Leader) being declared. If you expect PULSIN to return a value >255 then make sure to give it a WORD variable to store that result in.
