16F628 without Max232
hello i am trying to send "hello" without Max232 IC , i am getting characters like this
*ë©::
*ë©::
*ë©::
*ë©::
*ë©::
i am useing 16F628 with 4 MHz Xt
and the codes re
RCSTA=$90
TXSTA=$25
SPBRG=103
loop:
hserout ["hello",13,10]
goto loop
am i making a mistake?
if you don't se any inverter like MAX232, you can't use HSEROUT. you'll need to use SEROUT or SEROUT2 and set it to XYZbaudrate AND Inverted mode.
If you plan to send data to your PC without any Max232, better if you, of course, use a current limiting resistor between PIC and PC AND make sure the Serpin is set to high level before sending the first data. This will avoid to have odd result on the first sent character.
The other option is to use the DEBUG command. Its very similar in command struction to Hserin/Hserout. Hserout or Hserin will require a MAX232.
Thanks it's working
Yesssssss
When i change the codes like this it works :)
include "modedefs.bas"
loop:
serout portb.2,4,["hello"]
goto loop
Thanks all of u for help
