Need help to modifie a thermostat project
hi im a electronic hobbyist and i found an open source thermostat project want to made it but i cant found in my country the ds18B20 :mad: we have here just the ds1820 im not a programmer :confused: can some on help me plzz to modifie program to work perfectly with ds1820 thanks in advence
Re: Need help to modifie a thermostat project
I'm thinking you'll have to translate the program into English. There area few souls here that are multilingual but not many.
Are you required to use a device such as the ds1820?
Perhaps your project involves obtaining a temperature reading from one or more sensors?
Why not consider a simple thermistor.
You can use PBP's "POT" command with as many pin+thermistors as you like.
Very simple do to.
Alternatively, you might try putting an Oscope on the digital output of the ds1820 as it outputs 16 bit words.
You should be able to figure out how to get the pic to interpret those with a little work.
If it were me, I would go for the thermistors.....get to the end goal for much less work. :-]
Good luck on your project!!
