Pin High for 13 seconds while....
Life cycle tester: I need to hold a pin (Relay1) high for about 10 seconds while I am doing other things with other pins. I want to drive a relay and that runs a Pic outputting a square wave at 20 Hz for 200 pulses. I want to count the pulses using TMR0. Then I need Relay1 to go low for about 3 seconds .
I have 2 problems right now:
1) Relay1 pin goes high for a blip then low so I need to get some kind of timing loop going for the relay cycle. But how do i keep other things going on with other pins at the same time?
2) my test cycle counter goes to 255 and resets and I want it to go to 9999 cycles before going back to 0 and so does my pulse counter.
Any help or push in the right direction would be great
Init:
INTCON.7 = 0 'Disable interrupts
OPTION_REG = %00111000
TRISB = %01100111 'Setup Port B
PORTB = %00000000 'Clear port B pins
T_cyc Var Byte
T_cyc = 0
PAUSE 1000 'Pause for the LCD to wake
Relay:
T_cyc = T_cyc + 1 'Test cycle counter
Relay1 var PORTB.5
High Relay1 'Drive relay pin 26 high for 13 seconds
Goto Main
MP_Count var PORTB.6 ' Holds count value
MP_Count = 0 ' Clear pulse counter
TMR0 = 0 ' Clear TMR0 counter
MP_Count = TMR0 ' Get TMR0 count
LCDout $fe, 1, "Test # ",dec4 T_cyc 'Test cycle (0-9999 tests)
LCDout $fe,$c0, DEC5 MP_Count, " Pulses"
Low Relay1
PAUSE 4000
GOTO Relay
Using a Pic 16F870
