It would be real beaut if there were 2 additional functions, which would suit a lot of stuff I am doing:
1. DTMF decoding and converting to ASCII
2. FREQIN to about 10kHz
As I say, these would suit me a whole lot.
32-bit interger math (longs) would be very nice. DIV32 helps but "real" longs would be very nice.
Hello Muddy,
Your frequency can easily be calculated by using Pulsin in a subroutine...This has not been tested, but the idea is there. I wrote one a long time ago for RPM on a 2 stroke airplane engine.
routine:
Pulsin Pin1, 1 ,Pos 'measures the positive Pulse
Pulsin Pin1, 0, Neg 'measures the negative Pulse.
Wavelength/cycle=Pos + neg 'Adds them together for the full length
Frequency=1000/Wavelength '(in ms)
Frequency=1000000/Wavelength '(in us)
return Frequency
DTMF is a frequency...Thus the above routine can measure the frequence of the DTMF and tell you which number you pressed...
Dwayne
32 bit integers. Better interrupt support would be nice too.
Hi, DwayneQuote:
Originally Posted by Dwayne
Just a little example of what you wrote ... also applied to a model RPM Meter !!!
DTMF might be a little trickier as there are TWO mixed frequencies ... but there are cheap and excellent DTMF decoders on the market ...
Why re-invent the wheel ???
Even if it's not important.. it could be interesting to have
Hardware and Software block definition
Same for all other function like DEBUG, HPWM, HSERIN....Code:'
' Lcd
With LCD
Data = PORTA,0 ' Set data pin of LCD to
' PORTA.0-PORTA.3
RS = PORTB,4 ' Set RS bit of LCD to
' PORTB.4
E = PORTB,5 ' Set E bit of LCD to
' PORTB.5
LINES = 4 ' 4 Lines LCD
COMMANDUS = 2000 ' Command delay time in uSec
DATAUS = 50 ' Data delay time in uSec
EndWith
I/O Alias block
Variable type blockCode:Alias PORTA
.0 = SCL
.1 = SDA
.2 = StatusLED
EndAlias
Code:BYTE
CounterA
Discard
BlahBlah
EndBYTE
Hello alain,
DTMF decoders are very hard to find. I know there are many models on the market but they seem to be unavailable.
Clare, Motorola, SDI, TI and some others manufacturers have stated the end of manufacture for this part!
Zarlink are another company that make this part, but they are not interested to sell it for an order under 10000 units.
I think a function like DTMF Decoding would be very interesting in the next release of PBP.
salut!
Martin
Hi, Martin
Opening my favourite component retailer cat. I find at once the TCM5089 ...second the MT8870 from MITEL ...
so, you're in Canada ... lots of differences from here.
THE Heavy method is found in the NE/SE 567 Datasheet : 4 couples of PLL circuits ... but, I think there's an easier way.
