Help for a new boy
Hi All
A bit new to all this but learning fast (I hope), and this seems a stupid question, but I don't know and if you don't know you have to ask so........
I have code which works fine on a 12f683, but I had originally planned to use 12f629 and so want to recode it. Now I know there are certain differences, but at the moment I cant even get simple code to work on the 629.
I have this that works on the 629
' Name : Test44.pbp
' Compiler : PICBASIC PRO Compiler 3.07
' Assembler : PM
' Target PIC : 8-pin PIC12F629
' Oscillator : 4MHz internal
' Description : test file PICBASIC PRO program to show button press on LED.
DEFINE PIC12F629, INTRC_OSC,INTRC_OSC_NOCLKOUT,WDT_ON,PWRT_ON,MCLR_OFF, BOD_ON , CPD_OFF , PROTECT_OFF
Define OSCCAL_1K 1 ' PIC12F675, Calibrate internal oscillator
CMCON = 7 ' Analog comparators off
CLEAR
LED var gpio.1 ' Alias GPIO.0 to LED
PB Var GPIO.0 ' Alias GPIO.3 to push button
' Button press turns on LED
If PB = 0 Then ' If button pressed...
low LED ' Turn on LED
Else
high LED ' Turn off LED
Endif
Goto mainloop ' Do it forever
However if I add lines after "'Button press ...." such as a short HIGH/PAUSE/LOW/PAUSE sequence all I get is the Led going High and the Prg appears to halt.
If I try similar code on the 683 it works - dont even have the opening DEF in there
Any help gratefully received
Confused Colin
Re: Help for a new boy
Colin
You haven't defined the label for 'mainloop' and tell the processor to goto mainloop. You're probably getting errors while compiling this code.
Please tell us what version of PBP you are using, and if you know whether you are using MPASM or not.
Good catch Jerson . . .
just checked the code and have got mainloop defined - don't why it didn't copy over.
' Name : Test44.pbp
' Assembler : PM
'Button press turns on LED
mainloop:
Else
Endif
I am using PBP3.071 and and I guess MPASM if that is the default installed.
It will be easier for members to help if you post all your code. You don't have any CONFIGs, no oscillator setting, LED is not defined as a beginning.
Are the proper pins digital by default on this device?
The earlier code posted has all the detail
Led var GPIO.1 etc
DOES NOT WORK IN pbp3.xxx which is why I asked you, in fact it does not work in MPASM with ANY version of PBP as it is for the PB assembler which PBP3.xx does not support.
@ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
above would be how to config MPASM in PBP versions earlier than PBP3.00
PBP 3.xx configs are done as in below:
__CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _WDT_ON
;__config _CONFIG2, _WRT_OFF & _BOR40V
All that said you will need to make appropriate changes to what I posted for your particular chip, but that is how to format your configs
Thanks for the config help
