DT_Analog.pbp
Good day to all of you ,
I am going to use the DT_Analog.pbp include file But I have the " ERROR: Macro DIV32?WW not found in macro file" when compiling.
I have copied the file in the folder where the PBP executable file is stored.
I am using pic 18 f 252 with PBP_2.50B and I am using longs.
Thanks in advance for any help ,
regards,
Ambrogio
Re: DT_Analog.pbp
It uses DIV32, that doesn't exist when PBP LONG is used.
You can replace this:
R2 = DTadAccum ; put 32-bit accumulated value in PBP
R0 = DTadAccum[1] ; registers, prepare for DIV32
ADvalue = DIV32 DTadDivisor ; get the average value
With something like this:
Tmp VAR LONG
Tmp.word0 = DTadAccum ; put 32-bit accumulated value in PBP
Tmp.word1= DTadAccum[1] ; registers, prepare for DIV32
ADvalue = Tmp/DTadDivisor ; get the average value
Re: DT_Analog.pbp
thanks for the reply,
I have modified the include file per your direction and no more errors are displayed.
I loaded the sample program from Darrel site.
I am using PIC18f252, pbp 2.50, longs at 40 Mhz clock.
I have CH-1=12 and CH-2=12 on the LCD.
Thanks, Ambrogio
this is the set up:
DEFINE ADC_BIT 10
DEFINE ADC_CLOCK 2
DEFINE ADC_SAMPLEUS 5
ADCON1=%10001101
ADBITS = 12
FOR ADchan = 0 to 1 ; Do both AN0 and AN1
GOSUB GetADC ; Get A/D value
IF ADchan = 0 THEN
LCDOUT $FE, $80 ; LCD line 1
LCDOUT $FE, $C0 ; LCD line 2
LCDOUT "CH-",DEC1 ADchan," = ",DEC ADvalue," "
NEXT ADchan
GOTO Main:
GOTO OverDTAnalog
ADchan VAR BYTE ; global - A/D channel to use
ADbits VAR BYTE ; global - # of bits in result
ADvalue VAR WORD ; global - the final A/D value
ADmax VAR WORD ; global - Max A/D value at this resolution
DTadCount VAR WORD ; local - sample count
DTadDivisor VAR WORD ; local - averaging divisor
DTadShiftR VAR BYTE ; local - bits to shift for UnderSampling
DTadAccum VAR WORD[2] ; local - 32-bit sample accumulator
GetADC:
IF (ADbits >= 10) THEN
DTadShiftR = 0 ; 10 11 12 13 14 15 16
LOOKUP2 ADbits-10,[ 1, 4,16,64,256,1024,4096],DTadCount
LOOKUP ADbits-10,[ 1, 2, 4, 8, 16, 32, 64],DTadDivisor
DTadCount = 1
DTadDivisor = 1
DTadShiftR = 10 - ADbits
LOOKUP2 ADbits,[0,1,3,7,15,31,63,127,255,511,1023, _
2046,4092,8184,16368,32736,65472],ADmax
DTadAccum = 0 : DTadAccum[1] = 0 ; clear the accumulator
DTadLoop:
ADCIN ADchan, ADvalue ; get 10-bit sample
DTadAccum = DTadAccum + ADvalue ; add it to the accumulator
IF DTadAccum < ADvalue THEN ; if low word overflowed
DTadAccum[1] = DTadAccum[1] + 1 ; increment the high word
DTadCount = DTadCount - 1 ; done with this sample
IF DTadCount > 0 THEN DTadLoop ; loop if not done with ALL samples
' R2 = DTadAccum ; put 32-bit accumulated value in PBP
' R0 = DTadAccum[1] ; registers, prepare for DIV32
' ADvalue = DIV32 DTadDivisor ; get the average value
Tmp VAR LONG
ADvalue = ADvalue >> DTadShiftR ; Shift right if < 10-bit
OverDTAnalog:
Re: DT_Analog.pbp
This code should work with long and word compiler option.
GOTO OverDTAnalog
#IF __LONG__
DTadAccum VAR LONG ; local - 32-bit sample accumulator
#ELSE
#ENDIF
GetADC:
DTadCount = 1
DTadDivisor = 1
DTadLoop:
#IF not __LONG__
#ENDIF
#IF __LONG__
ADvalue = DTadAccum / DTadDivisor
#ELSE
#ENDIF
OverDTAnalog:
Re: DT_Analog.pbp
Hmm, will that work on 2.50B?
I thought the pre-processor directives like #IF / #ELSE / #ENDIF was introduced in PBP3.
Re: DT_Analog.pbp
Re: DT_Analog.pbp
Sadly, updating to v3.0 is not an option for a lot of us.
Re: DT_Analog.pbp
Thanks a lot for the assistance on this matter.
The attached files works with pbp2.50B ( I tested it with LONGS ), PIC18F252@40 MHz.
I suggest Darrel to include it in his site. It could be useful to somebody.
Thanks again for all.
Ambrogio, IW2FVO
GOTO OverDTAnalog
'#IF __LONG__
'#ELSE
' DTadAccum VAR WORD[2] ; local - 32-bit sample accumulator
'#ENDIF
GetADC:
DTadCount = 1
DTadDivisor = 1
DTadLoop:
' #IF not __LONG__
' IF DTadAccum < ADvalue THEN ; if low word overflowed
' DTadAccum[1] = DTadAccum[1] + 1 ; increment the high word
' ENDIF
' #ENDIF
'#IF __LONG__
'#ELSE
'#ENDIF
OverDTAnalog:
