3 Attachment(s)
Using SPI hardware
For several days I'm trying to use the MSSP
The complete project is to use 4 x PIC18F45K22 as slave and another one as Master.
At this time I just simulate data between 1 slave and the master with Proteus 8 and... the simulation works.
Unfortunately, test with my PCB makes me crazy.
When Master asking to slave with a "?" I expect to receive "!WAY0625"
Attachment 7123
or HEX: 21 57 41 59 30 36 32 35
This is simulation give, but in fact (Real PCB) the slave never answer the good message beginning by "!"
Attachment 7124
don't care about the "41 hex" in place of "3F hex", this is because I'm trying other than "?" to begin TX.
The problem is: Why $10 on MISO (or other stupid values)
Here is my code:
'* Name : master.BAS *
'* Author : Herve Helleboid *
'* Notice : Copyright (c) 2013 HYTEM *
'* : All Rights Reserved *
'* Date : 02/11/2013 *
'* Version : 1.0 *
'* Notes : *
DEFINE OSC 64
TRISA = %00000000
TRISB = %00000000
TRISC = %10010000
TRISD = %10000000
TRISE = %00000000
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00000000
ANSELE = %00000000
' configuration USART2 (communication avec FAV)
RCSTA2 = $90 ' Enable serial port & continuous receive
TXSTA2 = $20 ' Enable transmit, BRGH = 0
SPBRG2 = 77 ' 9600 Baud @ 48MHz, 0,16%
' configuration USART1 (communication RS232 externe)
RCSTA1 = $90 ' Enable serial port & continuous receive
TXSTA1 = $20 ' Enable transmit, BRGH = 0
SPBRG1 = 103 ' 9600 Baud @ 64MHz, 0,16%
SSPEN VAR SSP1CON1.5 ' SSP Enable bit
CKP VAR SSP1CON1.4 ' Clock Polarity Select
SMP VAR SSP1STAT.7 ' Data input sample phase
CKE VAR SSP1STAT.6 ' Clock Edge Select bit
SSPIF VAR PIR1.3 ' SPI interrupt flag
SS0 var PORTB.3
SS1 VAR PORTB.1
SS2 VAR PORTC.2
SS3 VAR PORTC.1
LED VAR PORTE.0
slave var byte
i VAR BYTE ' loop counter
a VAR BYTE[6] ' Holds characters read from slave
HIGH SS0 'slaves are waiting (slave select pin)
HIGH SS1
HIGH SS2
HIGH SS3
HIGH LED
PAUSE 300
LOW LED
pause 300
hserout ["rdy",13,10]
SSP1CON1 = %00100010
SSPIF = 0 ' clear buffer full status
mainloop:
GoSub getdata ' initiate conversion and receive data
hserout ["lst ",STR a\7,13,10] ' display received string
high SS0
Pause 500
toggle led
GoTo mainloop ' do it forever
getdata:
low SS0
pauseus 10
SSPBUF = "?" ' send ? to start conversion
GOSUB letclear ' wait for buffer to clear
IF SSPBUF<>"!" Then getdata ' wait for reply (!)
For i = 0 to 6 ' loop for 7 characters
SSPBUF = 0 ' write to SSPBUF to start clock
GOSUB letclear ' wait for receipt
a[i] = SSPBUF ' store received character in array
Next i ' get next character
letclear:
IF SSPIF = 0 Then letclear ' wait for SPI interupt flag 1=TRx complet must be cleared
PauseUs 25 ' 25uS fudge factor
SSPIF = 0 ' reset flag
and
' Name : SPISLAVE.pbp
' Compiler : PICBASIC PRO Compiler 2.6
' Assembler : PM or MPASM
' pic18f45k22 @ 16MHz PLLx4 = 64MHz
DEFINE OSC 64
TRISA = %00100000
TRISB = %00000000
TRISC = %10011000
TRISD = %10001000
TRISE = %00000000
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00001000
ANSELE = %00000000
' Allocate RAM
dataout VAR BYTE[8] ' Data out array
SSPIF VAR PIR1.3 ' interrupt flag - last bit set
a VAR BYTE[6] ' Holds 6 characters of data
led var PORTA.4
way var byte 'n° de voie
' SSP1CON1 = %00000101 ' configure SPI slave, no SS
SSP1CON1 = %00000100 ' configure SPI slave with SS
CKP = 0 ' clock idle low
CKE = 0 ' transmit on idle to active transition
SSPIF = 0 ' clear SPI interrupt
SMP = 0 ' sample in middle of data
SPBRG1 = 25 ' 38400 Baud @ 64MHz, 0,16%
DEFINE ADC_BITS 8 ' ADCIN resolution (Bits)
DEFINE ADC_CLOCK 7 ' ADC clock source (Frc)
DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
dataout[0] = 87 ' Preset output WAY0625
dataout[1] = 65
dataout[2] = 89
dataout[3] = 48
dataout[4] = 54
dataout[5] = 50
dataout[6] = 53
HIGH LED
PAUSE 300
LOW LED
ADCIN 23,way
IF way < 30 then
way = 48 'way 0 for 470R
goto mainloop
IF way < 60 then
way = 49 'way 1 for 2K2
goto mainloop
IF way < 90 then
way = 50 'way 2 for 3K9
goto mainloop
way = 51 'way 3 for 10K
mainloop:
SSPEN = 0 ' disable/enable SSP to reset port
SSPEN = 1
SSPBUF = "!" ' send reply $21 dec = 33
GoSub letclear ' wait for byte received
IF (SSPBUF <> "?") Then mainloop ' wait for ? to start conversion
toggle led
For i = 0 to 6 ' loop for 7 array locations
SSPBUF = dataout[i] ' send array variable
GoSub letclear ' wait until buffer ready
Next i ' next location
goto mainloop
letclear:
IF SSPIF = 0 Then letclear ' wait for interrupt flag
Attachment 7125
Any idea ? Someone can help ?
herve
Re: Using SPI hardware
same as november 6
Measuring... Trying to understand what's wrong...
As I'm using PIC for my job... I'm sad... Too many hours (weeks) and... working now to make fast PIC's communication without pbp example (just one example found and not working ).
To be electronician is not an easy life !
As nothing seem's to work... (not using simulation program now but real hardware)
Using now the smallest program to test what's wrong:
DEFINE OSC 64
TRISA = %00000000
TRISB = %00000000
TRISC = %10010000
TRISD = %10000000
TRISE = %00000000
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00000000
ANSELE = %00000000
' configuration USART1 (communication RS232 external)
SS0 var PORTB.3
LED VAR PORTE.0
slave var byte
a VAR BYTE[6] ' Holds 6 characters read from slave
BF VAR SSP1STAT.0
HIGH SS0 'slave not in use
HIGH LED
PAUSE 300
LOW LED
Pause 50
SSP1STAT = %00000000
mainloop:
pause 200
low SS0
pauseus 5
SSP1BUF = "?"
while BF = 1 : wend
pauseus 10
SSPIF = 0
high SS0
hserout [SSP1BUF," ",dec SSP1BUF,13,10] ' display received char
toggle led
' Name : SLAVE.pbp
DEFINE OSC 64
TRISA = %00100000
TRISB = %00000000
TRISC = %10011000
TRISD = %10001000
TRISE = %00000000
ANSELA = %00000000
ANSELB = %00000000
ANSELC = %00000000
ANSELD = %00001000
ANSELE = %00000000
' Allocate RAM
led var PORTA.4
BF VAR SSP1STAT.0
CKE = 1 ' transmit on idle to active transition
SSPEN = 1
HIGH LED
PAUSE 300
LOW LED
mainloop:
SSP1BUF = "!" ' send reply $21 dec = 33
while BF = 1 : wend
PAUSEUS 10
SSPIF = 0
toggle led
goto mainloop
Master send "?" and need to receive "!"
doing it forever
AS I can see on my logic analyzer
MASTER send $3F (OK it's ? or decimal 63)
SLAVE send $21 (OK its ! or decimal 33)
This is measured with USBEE SX.
As I have a RS232 hardware connected to the PIC master (TX1) my master prog send to RS232 the received character
instead of receiving "!" (dec 33) it is always " " (dec 32)
sometimes also receiving strange characters
So... I was thinking that last bit is not recognized but:
If I change (slave prog) the character "!" by example by "W" or "0" it works fine every time !
I tried to send other different characters and for some of them, it's good...
For others it's decimal value -1 or decimal value + 1
Any help ?
I haven't looked that close at your code yet but have you tried putting the logic analyzer on the UART output of the PIC to verify what it is actually sending? Perhaps there's some baudrate issue, some problem with a USB-COM dongle (if you're using one) or something else on that side of equation. On the other hand I see you're outputting rdy at the start and I expect that to display properly. What if you change that to Ready! does it still display properly?
You could always try:
RCSTA = $90 ' Enable serial port & continuous receive
TXSTA = $24 ' Enable transmit, BRGH = 1
SPBRG = 130 ' 9600 Baud @ 64MHz, -0,02%
SPBRGH = 6
BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
Hello Henrik,
Thank you for your message
I have tryed your code and change rdy to ready without any result. I will try tomorrow on another computer (direct RS232 port, no USB dongle) to see if the problem isn't here.
Best Regards
Are you certain your configs are set correctly to operate that PIC @ OSC 64 ?
@ Henrik
On another computer (real RS232 port) = same result
@Archangel
Hi and thank you for your reply
Do you think I forgot something in config bit ?
I'm not expert... May be you can check my config bits:
Attachment 7127
Maybe I can try at 16MHz, but I choose this pic because of 64MHz.
I had never used the MSSP module in slave mode Before but I just had a play with two 18F25K20 devices, one as master and one as slave.
The master sends the letters "A" to "Z" and outputs both what it sends and what it recieves to the serial terminal.
The slave responds with the letters "Z" to "A". It outputs what it receives and what it sends to the serial terminal.
At this time I did not have time to implement and test the SS-line but apart from that it appears to work as expected.
You might be able to gain some insight into your trouble by looking at these two programs.
Here's the code for the master:
'* Name : SPI Master.pbp *
'* Author : Henrik Olsson *
'* Notice : Copyright (c) 2013 [Henrik Olsson] *
'* Date : 2013-11-12 *
'* Version : 1.0 *
'* Notes : Designed to run on 18F45K20, AMICUS18 platform. *
DEFINE OSC 64 ' Default oscillator speed on the AMICUS18 is 16*4MHz
DEFINE LOADER_USED 1 ' We're using a bootloader.
DEFINE HSER_SPBRG 138 ' 115200 Baud @ 64MHz, -0,08%
SPBRGH = 0
TRISC = %10010110 ' RX, TX, SDO, SDI, SCK, N/U, N/U, CS
TRISB = %11111111 ' N/U, N/U, N/U, N/U, N/U, N/U, N/U, N/U
' Aliases for the MSSP module status and control bits.
SSPEN VAR SSPCON1.5 ' SSP Enable bit
CKP VAR SSPCON1.4 ' Clock Polarity Select
SMP VAR SSPSTAT.7 ' Data input sample phase
CKE VAR SSPSTAT.6 ' Clock Edge Select bit
BF VAR SSPSTAT.0 ' Buffer full flag.
' Set up the MSSP module.
CKP = 0 ' Clock idles low
CKE = 0 ' Transmit on idle to active transition.
SMP = 0 ' Sample in middle of data
SSPEN = 1 ' Enable SPI pins
SSPCON1.0 = 1 ' Slow down SPI clock to Fosc/16 for now.
i VAR BYTE
Response VAR BYTE
Response = SSPBUF ' Dummy read to buffer and BF-flag
HSEROUT ["Master start...", 13]
HSEROUT ["TX - RX",13]
Pause 5000
For i = "A" to "Z" ' Send letters A to Z
SSPBUF = i ' Load buffer with content
While BF = 0 : WEND ' Wait for operation to complete
Response = SSPBUF ' Read response
HSEROUT [i, " - ", Response, 13]
PAUSE 10
NEXT
HSEROUT ["Done.....", 13]
Pause 5000
Goto Main
And here's the code for the slave:
'* Name : SPI Slave.pbp *
'* Version : 1.0 *
SPBRGH = 0
TRISC = %10011111 ' RX, TX, SDO, SDI, SCK, N/U, N/U, CS
BF VAR SSPSTAT.0 ' Buffer Full bit
While PortC.4 = 1 : WEND ' Wait for SCK pin to be idle before enabling MSSP
SSPCON1 = %00100101 ' Slave mode, no SS
i VAR BYTE
Response VAR BYTE
HSEROUT ["Slave start...", 13]
HSEROUT ["RX - TX", 13]
For i = "Z" to "A" STEP -1
While BF = 0 : WEND ' Wait for data to arrive
Response = SSPBUF ' Read data from buffer, clears flag.
HSEROUT [Response, " - ", i, 13]
NEXT
HSEROUT ["Done...",13]
Goto Main
Hello again,
Looking at the slave code in post #3 above it says
The setting and comment does not match, Setting the CKE bit makes the slave, in this case, output data on active to idle state of the clock. But, looking at the master code it is set up to sample the data in the middle of the cycle. I'm not sure if this is the actual problem but comparing it to my examples it's something that differs.
Dear Henrik, and other who tryed to help me.
Today I made a new prototype.. Soldering new components on a new (but same) professionnal dual layer PCB and, using same programs
Plugin and.... Working !
I really don't know what's wrong with the first one.
My new prototype has just what is needed to test the SPI. (Only 2 pic and max232a)
Trying now to write the complete program... God bless me ;)
Thank you very much
Attachment 7129
