HSEROUT/HSERIN with RS422/485 Driver
Hello,
I am trying to work out how to use HSEROUT/HSERIN on 16F88 combined with a 75176 diff. bus tcvr chip. I want to create bi-directional, half duplex communication over a single pair.
I am stuck on how to drive the 75176 RE/DE pins to enable transmit and receive. I can join the RE and DE pins together and then connect them to an available I/O pin. Sending this pin high will put the 75176 into TX and sending it low for RX. Is there a flag I can poll to set/clear this pin based on the status of HSEROUT (i.e. high only while it is actually transmitting data). I have tried setting the pin before the HSEROUT statement and clearing it after but this doesn't work. Obviously the hardware serial is doing it's thing in the background whilst the next commands are being processed.
At this point I have confused myself and need to ask for assistance!
Andy
Re: HSEROUT/HSERIN with RS422/485 Driver
The TRMT bit (TXSTA.1) reads 0 (TSR full) while the USART is still shifting out data.
Wait for it to go to 1 (TSR empty) before switching back to receive mode.
TRMT VAR TXSTA.1
HIGH RE_DE
HSEROUT ["Hello World!"]
WHILE NOT TRMT : WEND
LOW RE_DE
Be sure to have "Fail-Safe" resistors that bias the network to "True Idle" levels.
Hi Darrel,
Yet again another simple solution to a problem I have spent way too long on......... Thank you.
I do have the bias resistors on the bus. I read one of your previous posts containing a link to a (Maxim?) datasheet, showing how schottky diodes can be used - very interesting. Now that I have a solution to my initial problem I will work on reducing the current consumption to an acceptable level.
Andy
Hi Darrel,
I must admit I have only quickly glanced over the article. One thing that puzzles me a bit is how the diode arrangement actually works to dampen the reflections on the buss.
I have a bit of a background in RF and I always assumed the terminating resistor was selected to be approx the same impedance as the line. This is transmission line theory and, in this instance, the termination resistance equals the characteristic impedance of the transmission line, and therefore the line operates with low reflections or SWR (Standing Wave Ratio). I would like to understand more on how the diodes produce the same effect without the terminating resistor. However it works it sure seems to be better arrangement.
Andy
Well, here's a quote from the previously mentioned appnote... http://www.maxim-ic.com/appnotes.cfm/an_pk/1090
Schottky-Diode Termination
Schottky diodes offer an alternative termination when power dissipation is a concern. Unlike other
termination types, Schottky diodes do not attempt to match the line impedance. Instead, they simply
clamp the over- and undershoots caused by reflections.
This image is an example of unclamped overshoots ...
Ignore the yellow line.
http://support.melabs.com/DT/OverShoot.png
Ok - got it now. Just a different method of achieving a similar result.
One has to wonder then why the terminating resistor is by far more popular? The diode arrangement seems more versatile and consumes less current......
Andy
