Need Help in Measurement of Voltage
Dear All.
I am new in the PIC project and currently working with a project that requires to measure battery voltagr from 10 to 18 volts.As i have read nearly all the post in this forum i have notice that the only way to read voltages into a PIC is to limit the voltage between 0 to 5 volts.
Many have recomended to use resistors but is there any way to get muct better reading as resistors will change when it is subjected to heat.
Basically i want to read the voltages of a car battery and also the fuel indicator and change all of this to a digital read out.One way i found out via the internet is to use OBD (Onboard dignostic) codes where we could use the PIC16F84 to conver the manufactures code to display the values comming out of the car ECU (Electronic Control Unit) on all injectors car before 1996.
Has anyone done such a project before that can give me a helping hand on a better way to read voltages using at least an op-amp or an isocoupler.Or has anyone built a OBD system before?
Thank you
Measuring Voltages and OPAMP circuits
Hi Steave and Melanie.
Thanyou foe the feedback.Just let you know that i will be starting of the project next week and i have just purchase the MEL LAB "X1" board.
Just wondering if you guys have any schematic drawings of the opamp where we can scale down the voltages from 10 - 18 volts dc to 0 to 5 volts dc.
i have printed out all the foulars anf also the comments given in this forum and i remember clearly reading and artical by Melanie and also Steave.
If you could help me get the schematic diagram or even an url that will show how to scale down the voltages this will be much help.
Currently i have manage to read temperatues from the "X1" for and this will help me get the project running as i will be using it to measure cabin and outside temperature of the car.
As for the obd codes there isn't any site that will show the conversion of the obd codes so this will be a problem as i am very new in the PIC system and also programming.
Thanks for the advice and hope to hear from you on the schematic diagrams.
thank you & God Bless
