32 Bit NEC IR Constants/Variables
Interested in suggestions for best dealing with 32 Bit values as used with NEC IR codes. How best would a collection of IR commands of these be stored and used? (VolUp, VolDn, ChUp, ChDn, etc.) (Each 32 Bits) As Constants or as Variables? Using the Long version of the compiler? 2-16 Bit Words linked/associated together? In regards to sending data, what would the best way of clocking/shifting these out be? One way would be a For/Next Loop of 0-15 for the low word, then do again for the high word. (OutBufferHI.0 and OutBufferLO.0)
Re: 32 Bit NEC IR Constants/Variables
Oops...Asked too fast.
Looks like it's 2 address bytes followed by 2 command bytes.
Each 2nd byte is an inverted copy of the first.
No longs required and the Address versus Command are different animals.
NEC IR Protocol documentation
Example PIC Code
Dave,
Thanks very much for the info.
Very informative website you have there.
Jay Zebryk
