Problem with HSEROUT/HSERIN
I have this code:
Gain:
HSERIN [STR Name\25\"*"] : Pause 250
HSEROUT [STR Name,"*"]
for pass=0 to 24
Name[pass]=0
next pass
Goto Gain
First time when program starts. I can see on serial communicator when data 'Home*' is received. Nothing comes as output
I send it again 'Home*' it outputs 0
Third time I send 'Home*' it outputs 'Home*'
THEN I send 'abcd*' it outputs 'Home*'
I send it again 'abcd*' it outputs 'abcd*'
Similarly every different data after this comes to the output after sending it twice.
Why is this happening?
Re: Problem with HSEROUT/HSERIN
Have you declared Name as an array of 25 bytes?/Henrik.
Yes. Variables are able to hold the value.
Then I don't know...
That can't be all of the code can it? Try to reduce the code to the bare minimum which still shows the issue, then post that code.
I've tried the following on a 18F25K20 running at 64MHz
DEFINE OSC 64
DEFINE LOADER_USED 1 ' We're using a bootloader.
DEFINE HSER_SPBRG 138 ' 115200 Baud @ 64MHz, -0,08%
SPBRGH = 0
BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
Name VAR BYTE[25]
pass var byte
Pause 200
HSEROUT["Program start.",13]
Gain:
for pass=0 to 24
Name[pass]=0
next pass
Goto Gain
It seems to work fine using the serial communicator terminal built into MicroCodeStudio...
Here is the code, the problem is there:
'-----------------Defines & Includes----------------
Include "modedefs.bas"
DEFINE OSC 20
'------------------------Configuration Fuses-------------
ifdef PM_USED
device pic16F877A, xt_osc, wdt_on, lvp_off, protect_off
__CONFIG _HS_OSC & _WDT_OFF & _LVP_OFF & _CPD_ON & _CP_ALL & _PWRTE_ON & _BODEN_ON
@ ERRORLEVEL -306 ' SUPRESS PAGE BOUNDRY ERROR
DEFINE HSER_SPBRG 64 ' 19200 Baud @ 20MHz, 0.16%
'--------------------REGISTERS-------------------------------
PAUSE 100
ADCON1=7 ' No Analog
CMCON=7
OPTION_REG=128
TRISA=0 : PORTA=0
TRISB=0 : PORTB=0 ' Enter Button Input
TRISC=%10000000 : PORTC=0 ' One pin to get data
TRISD=%10000000 : PORTD=0
TRISE=0 : PORTE=0
CCP1CON=0
Name Var Byte[25]
Pass Var Byte
Name=0 : Pass=0
Gain:
For pass=0 to 24
Name[pass]=0
next pass
Goto Gain
I have found im having the same problem, but I think Ive found a fix, you can tinker with it more. the program does not like the reset to 0 loop, also the name VAR make it 1 more than what you want so make it a 26, also put the loop first before doing serin/out and maybe add a pause 100 inside the loop. Im going to post my code for 8 bytes, its working great so far, i removed the loop and set each one seperately, it helped get rid of bad serial character loss/corruption dont know why though.
include "LCD_D.BAS"
Define OSC 20 'USE ECIO, NOT ECPIO
define HSER_BAUD 2400
DEFINE HSER_BITS 8
DEFINE HSER_CLROERR 1
RCSTA = $90
TXSTA = $20 'DO NOT USE $24
TRISC = %10000000
TRISD = 0
Name Var Byte[8]
Gain:
Name[0] = 0
Name[1] = 0
Name[2] = 0
Name[3] = 0
Name[4] = 0
Name[5] = 0
Name[6] = 0
Name[7] = 0
Name[8] = 0
HSERIN 5000,test,[STR Name\8] : Pause 250
HSEROUT [STR Name, 13, 10]
LCDOUT $FE, 2
LCDOUT $FE, $80
LCDOUT Name[0],Name[1],Name[2],Name[3],Name[4],Name[5],Name[6],Name[7]
pause 250
Goto Gain
test:
goto gain
Hope this helps or gives ideas!
