I'm trying to get more familiar with reading and writing to the memory of a 12F683 @4Mhz using PBP3 and simulating it on Proteus's serial out display.
What I want to know is how to write a large number, word sized, to memory, byte size, and then reassmble it. Like this
Memory 4 value is 10,000. What I'm trying to do is write memory 4 byte 0 value to memory location 3 and byte1 value to memory location 4. Then I want to read those bytes and assemble them into a word and display it.Code:
clear
trisio =%001101
gpio = 0
include "modedefs.bas"
#config
__CONFIG _INTOSCIO & _WDTE_ON & _CP_OFF & _MCLRE_OFF & _BOREN_ON & _IESO_OFF & _PWRTE_OFF & _CPD_OFF & _FCMEN_OFF
#endconfig
define OSC 8
osccon = %01111110 'sets 8 MHz oscillator
ansel = %00100101 '
cmcon0 = 7 ' Turn off comparatos
memory_output1 var byte ' memory variables
memory_output2 var byte
memory_output3 var byte
memory_output4 var word
memory_output5 var byte
memory_output6 var word
memory_output7 var word
write 0,5 'playing with memory
write 1,20
write 2,20
read 0, memory_output1
read 1, memory_output2
reaD 2, memory_output3
memory_output4 = memory_output3 * memory_output2 * memory_output1 * memory_output1
write 3, memory_output4.byte0
write 4, memory_output4.byte1
read 3, memory_output4.byte0
read 4, memory_output4.byte1
memory_output6 = memory_output4.byte0 & memory_output4.byte1 | memory_output7
serout2 gpio.1,84,[10,13,dec memory_output3," ",dec memory_output2," ",dec memory_output6,10,13]
serout2 gpio.1,84,[10,13,dec memory_output7,10,13]
serout2 gpio.1,84,[10,13,"----------------------------------------------",10,13]
I cut and pasted this code from the full program so it may be awkward in places. Your insights would be greatly appreciated.
