LCD display without firmware, problem with code
hi everybody, i m new in the forum!
i have a problem with my pic18m2 and display LCD. i don t fully understand the code written in the picaxe manual 3, but i thought giving the enable signal would switch on he display..
could someone give me a code to switch on the display or write "hello"?
i have only he LCD display connected with 6 pins to the pic (RS, EN, DB4 DB5 DB6 DB7)
the display doesnt seem to switch on the light even if i put 0 and 5 volt on the right pin! it s normal? does it need enable command?
please help me, i m a noob of electronics :)
Re: LCD display without firmware, problem with code
Your best bet is to ask on a PICAXE forum:
http://www.picaxeforum.co.uk/forum.php
This forum is for PIC BASIC PRO. Your PICAXE mcu uses a different compiler.
