Hi All,
I came across a 4-20mA board from MicroElektronika which uses the SPI to control the device, has anyone used such a board before?, I am looking for Code Examples, would anyone be able to assist?
gavo
Hi All,
gavo
Is it too much to ask to at least post a link to the board in question?
I could try to find it on their site but I won't so the best answer *I* can give you is that you can use SHIFTOUT to do bitbanged SPI or use the MSSP module (if the PIC has one) to do it "in hardware".
Hi
This is some code I wrote to use that board as a basic loop calibrator. Worked OK for me.
Take care
Alec
Code:'****************************************************************
'* Name : Encoder test *
'* Author : alec noble *
'* Notice : Copyright (c) 2012 alec noble *
'* : All Rights Reserved *
'* Date : 9/27/2012 *
'* Version : 1.0 *
'* Notes : *
__config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
'DEFINE OSC 20
'************************** setup LCD ****************************
DEFINE LCD_DREG PORTB ' Set Data to PortB
DEFINE LCD_DBIT 0 ' Set starting Data to Bit4
DEFINE LCD_RSREG PORTB ' Set Register Select to PortB
DEFINE LCD_RSBIT 4 ' Set RS line to PORTB.4
DEFINE LCD_EREG PORTB ' Set Enable to PortB
DEFINE LCD_EBIT 5 ' Set Enable line to PortB.5
DEFINE LCD_BITS 4 ' Set for 4 bit Bus
DEFINE LCD_LINES 2 ' Set number of lines to
CMCON = 7 'comparaters off - digital I/O on port A
trisb = 0 'all bits outputs
trisa = %00000111 'porta.0, 1, 2 input, all others output
cntr var word
cntr_1 var word
cntr_2 var word
preset var byte
sck var porta.6
sdi var porta.7
cs var porta.4
cntr = 200
preset = 0
cs = 1
lcdout $FE, $01
pause 5
lcdout "ahn_loop_cal"
pause 5000
lcdout $FE, $01
pause 5
lcdout dec cntr
'************************ Program **********************************
if porta.2 = 1 then set
if porta.0 = 1 then CW
if porta.1 = 1 then CCW
set:
pause 5
if porta.2 = 0 then main
preset = preset + 1
while porta.2 = 1 : wend
if preset > 4 then preset = 0
lookup2 preset, [200, 400, 600, 800, 1000], cntr
goto display
CW:
pause 5
if porta.0 = 0 then main
if cntr = 1023 then main
cntr = cntr + 1
goto display
CCW:
pause 5
if porta.1 = 0 then main
if cntr < 190 then main
cntr = cntr - 1
goto display
display:
cntr_1 = cntr * 4
lcdout $FE, $01, dec cntr_1, " mV"
pause 5
cntr_2 = cntr_1/2
lcdout $FE, $C0, dec2 cntr_2/100, ".", dec2 cntr_2//100, " mA"
goto DAC_out
DAC_out:
cntr_1.15 = 0
cntr_1.14 = 0
cntr_1.13 = 1 'GAIN OF 1
cntr_1.12 = 1 'turn on DAC output
low CS
' pause 5
shiftout sdi, sck, 1, [cntr_1\16]
high cs
while porta.0 or porta.1 = 1
wend
Hi Alec,
Many Thanks!, will try it!,
Hendrik the link is http://www.mikroe.com/click/rs485-5v/
Gavin
