Hi everyone,
Is there a way to use a constant to define the size of your array? eg:
DEV CON 60
LED VAR BYTE[WS]
It compiles, but throws up a syntax error (Haven't tested in the program yet)
Thanks.
Hi everyone,
DEV CON 60
LED VAR BYTE[WS]
Thanks.
That IS the way to do it.
But you can't name the constant DEV and then use WS in the array declaration.... You need to use a constant that actually have been declared./Henrik.Code:WS CON 60
LED VAR BYTE[WS]
Thanks, yep that was just a typo.
I'll have a go now I'm back with the project.
Simple problem in the end.
WS CON 60
LED VAR BYTE[WS]
Has to be above anything that uses it. If you don't it will compile O.K. but you will see a syntax error afterwards, and will not work.
Badger...
