LED 'Dot' Bargraph Issues - Newbie Code!
Hello all.
I have a PIC16F88 with ADC on PortA.0. I am measuring the voltage on a supply rail from 0-5VCD. I have a 35 LED display (3mm LEDs each) that is wired in a 7x5 matrix. I only want one LED to come on at any one time. Hence a moving 'dot'. The code works for the most part, but I have a minor annoyance. If I slowly raise the voltage I am measuring, there will be certain places on the dot display that has 2 x LEDs coming ON and flickering. It is like the ADC is just between bits and oscillates between two thus displaying 2 LEDs instead of one.
The code most certainly can be re-written a whole lot better and more efficiently. In my code, I simply look for values of adval and turn on the appropriate LED. On each LED turn-on, I also run a subroutine that first sets all the LEDs OFF. The ADC is set up as 8 bit. I know that is way more than what I need for resolution. 6 bit would probably work just fine.
Any help including a re-write would be greatly appeciated!
The code:
'Initialize variables PIC16F88
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
OSCCON=$60 'Set Internal Oscillator to 4MHz
DEFINE ADC_BITS 8 ' 8 bit A/D Conversion
DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
DEFINE ADC_SAMPLEUS 50 ' 50 uS A/D sample time
ANSEL = %00000001 ' Set pin (AN0) to analog input, the rest to digital
ADCON0 = %11000000 ' Set up A/D converter - Right Just., VDD REF., CH 0, ON
CMCON = 7
adval var word
pause 1000 'settle
high PortA.1 'Col1
high PortA.2 'Col2
high PortA.3 'Col3
high PortA.4 'Col4
high PortB.0 'Col5
low PortB.1 'Row1
low PortB.2 'Row2
low PortB.3 'Row3
low PortB.4 'Row4
low PortB.5 'Row5
low PortB.6 'Row6
low PortB.7 'Row7
Col1 var PortA.1
Col2 var PortA.2
Col3 var PortA.3
Col4 var PortA.4
Col5 var PortB.0
Row1 var PortB.1
Row2 var PortB.2
Row3 var PortB.3
Row4 var PortB.4
Row5 var PortB.5
Row6 var PortB.6
Row7 var PortB.7
mainloop:
ADCIN 0, adval
if adval <5 then
gosub ResetLEDs
goto mainloop 'Zero, all LEDs OFF
if adval >4 and adval <13 then
'Led2
gosub ResetLEDs
Row1 = 1
Col1 = 0
if adval >12 and adval <21 then
'Led3
gosub ResetLEDs
Row2 = 1
Col1 = 0
if adval >20 and adval <29 then
'Led4
gosub ResetLEDs
Row3 = 1
Col1 = 0
if adval >28 and adval <36 then
'Led5
gosub ResetLEDs
Row4 = 1
Col1 = 0
if adval >35 and adval <44 then
'Led6
gosub ResetLEDs
Row5 = 1
Col1 = 0
if adval >43 and adval <52 then
'Led7
gosub ResetLEDs
Row6 = 1
Col1 = 0
if adval >51 and adval <59 then
'Led8
gosub ResetLEDs
Row7 = 1
Col1 = 0
if adval >58 and adval <67 then
'Led9
gosub ResetLEDs
Row1 = 1
Col2 = 0
if adval >66 and adval <75 then
'Led10
gosub ResetLEDs
Row2 = 1
Col2 = 0
if adval >74 and adval <83 then
'Led11
gosub ResetLEDs
Row3 = 1
Col2 = 0
if adval >82 and adval <90 then
'Led12
gosub ResetLEDs
Row4 = 1
Col2 = 0
if adval >89 and adval <98 then
'Led13
gosub ResetLEDs
Row5 = 1
Col2 = 0
if adval >97 and adval <106 then
'Led14
gosub ResetLEDs
Row6 = 1
Col2 = 0
if adval >105 and adval <114 then
'Led15
gosub ResetLEDs
Row7 = 1
Col2 = 0
if adval >113 and adval <121 then
'Led16
gosub ResetLEDs
Row1 = 1
Col3 = 0
if adval >120 and adval <129 then
'Led17
gosub ResetLEDs
Row2 = 1
Col3 = 0
if adval >128 and adval <137 then
'Led18
gosub ResetLEDs
Row3 = 1
Col3 = 0
if adval >136 and adval <144 then
'Led19
gosub ResetLEDs
Row4 = 1
Col3 = 0
if adval >143 and adval <152 then
'Led20
gosub ResetLEDs
Row5 = 1
Col3 = 0
if adval >151 and adval <160 then
'Led21
gosub ResetLEDs
Row6 = 1
Col3 = 0
if adval >159 and adval <168 then
'Led22
gosub ResetLEDs
Row7 = 1
Col3 = 0
if adval >167 and adval <175 then
'Led23
gosub ResetLEDs
Row1 = 1
Col4 = 0
if adval >174 and adval <183 then
'Led24
gosub ResetLEDs
Row2 = 1
Col4 = 0
if adval >182 and adval <191 then
'Led25
gosub ResetLEDs
Row3 = 1
Col4 = 0
if adval >190 and adval <199 then
'Led26
gosub ResetLEDs
Row4 = 1
Col4 = 0
if adval >198 and adval <206 then
'Led27
gosub ResetLEDs
Row5 = 1
Col4 = 0
if adval >205 and adval <214 then
'Led28
gosub ResetLEDs
Row6 = 1
Col4 = 0
if adval >213 and adval <222 then
'Led29
gosub ResetLEDs
Row7 = 1
Col4 = 0
if adval >221 and adval <229 then
'Led30
gosub ResetLEDs
Row1 = 1
Col5 = 0
if adval >228 and adval <237 then
'Led31
gosub ResetLEDs
Row2 = 1
Col5 = 0
if adval >236 and adval <245 then
'Led32
gosub ResetLEDs
Row3 = 1
Col5 = 0
if adval >244 and adval <253 then
'Led33
gosub ResetLEDs
Row4 = 1
Col5 = 0
if adval >252 then
'Led34
gosub ResetLEDs
Row5 = 1
Col5 = 0
GoTo mainloop
ResetLEDs:
high PortA.1 'Col1
high PortA.2 'Col2
high PortA.3 'Col3
high PortA.4 'Col4
high PortB.0 'Col5
low PortB.1 'Row1
low PortB.2 'Row2
low PortB.3 'Row3
low PortB.4 'Row4
low PortB.5 'Row5
low PortB.6 'Row6
low PortB.7 'Row7
Re: LED 'Dot' Bargraph Issues - Newbie Code!
maybe take like 10 values and average them, then display the average instead? it may stop the jumpy LEDs a little.
Good idea Chirpy! I will give it a try....
When you find yourself writing the same section of code over and over with only changes to the values ....
It usually means you are doing it the hardest and least efficient way. :eek:
Instead of a bunch of IF/THEN's, use a little math, and a couple FOR/NEXT loops.
DEFINE ADC_BITS 10 ' 10 bit A/D Conversion
ADCON1.7 = 1 ' Right Justify A/D results
LED VAR BYTE
Row VAR BYTE
Col VAR BYTE
Idx VAR BYTE
Row_Pin VAR BYTE
Col_Pin VAR BYTE
adval VAR WORD
LEDcount CON 35
Spaces CON LEDcount + 1
Margin CON 1023 / Spaces
ADCIN 0, adval
LED = adval * LEDcount ; Determine which LED to light
LED = DIV32 (1023 - Margin) - 1
Row = -1 ; Turn OFF all dots
Col = -1 ; to prevent ghosting
GOSUB ShowDot
Row = LED // 7 ; convert LED to Row/Column
Col = LED / 7
GOSUB ShowDot
GOTO Main
ShowDot:
FOR Idx = 0 To 6 ; Set Row's
LOOKUP Idx,[1,2,3,4,5,6,7],Row_Pin
IF Idx = Row THEN
HIGH Row_Pin
LOW Row_Pin
NEXT Idx
FOR Idx = 0 TO 4 ; Set Column's
LOOKUP Idx,[9,10,11,12,0],Col_Pin
IF Idx = Col THEN
LOW Col_Pin
HIGH Col_Pin
NEXT Idx
And, for the two lights on at a time ... you may want to add this ...
http://www.picbasic.co.uk/forum/cont...ith-hysteresis
Wow, I cannot thank you enough Darrel! What elegant and efficient code! The difference between a newbie and a master. :-)
I will study the code and get familiar with LOOKUP (never used that fuction before) as well as understanding how it all works.
For example, setting Row = -1, I never knew you could set to a minus value. Don't really know what that is.
Brilliant code. Thanks a ton!!
Hi Darrel,
I tried the averaging routine but could not get it to work. In the code is has:
GOTO OverAverage
' -=-=-=-=-=-= Average Analog values -=-=-=-=-=-=-=-=-=-=
however, there is no OverAverage routine. Also, I replaced the word "Value" with "adval", but that did nothing.
Sorry, I am just not seeing this.
Thanks!
The OverAverage label is at the end of the code in that thread.
Maybe you didn't copy enough of it.
Hi Darrel,
Here is the entire code on that link:
'* Name : Average_Hyst.pbp *
'* Author : Darrel Taylor *
'* Date : 7/19/2005 *
'* Version : 3.0 *
'* Notes : Modified to use Hysteresis *
'* : Use as an INCLUDE file *
' This routine will keep a "Running Average" of 10-bit Analog Values
' Instead of adding a bunch of values together and then dividing by the number
' of samples, it averages each sample into the final result immediately.
' This eliminates the need for 32 bit math.
' To allow it to "Catch up" to large changes, set the FAspread to an
' acceptable range.
' Simply place the new number in VALUE and GoSub Average
' The Average (with Hysterisis) will be returned into the same variable VALUE
'---- [ User Options ] ---------------------------------------------------------
HystLevel CON 7 ' 7 = .7 of the Least Significant Digit
' Valid HystLevel is from 6 to 13
AvgCount CON 16 ' = Number of samples to average. For best response
' times, keep AvgCount as small as you can
FAspread CON 50 ' = Fast Average threshold +/-
' FAspread should be larger than the worst possible
' noise in the A/D conversion.
AVGchanged VAR BIT ' 1 indicates that the Average Value has changed
' you have to clear this bit after using it
ADavg VAR WORD ' Stores the current Average
ADhyst VAR WORD ' Stores the current Value for Hysterisis
Value VAR WORD ' Input / Output variable to be averaged
spread CON FAspread * 10 ' adjust spread *10 for Hyst.
GOTO OverAverage
Average:
Value = Value * 10 ' Scale value up for hysterisis
IF Value = ADavg Then NoChange ' if they're the same, nothing to do
IF ABS (Value - ADavg) > spread OR Value < AvgCount Then FastAvg
IF ABS (Value - ADavg) < AvgCount Then RealClose
ADavg = ADavg - (ADavg/AvgCount) ' Subtract 1 samples worth
ADavg = ADavg + (Value/AvgCount) ' Add in the new sample portion
GoTo AVGok
FastAvg: ' Catch up to the changing value
ADavg = Value ' Set Average to the current value
GoTo AVGok
RealClose: ' Reduce the sample size when
ADavg = ADavg - (ADavg/(AvgCount/4)) ' the average and the sample are
ADavg = ADavg + (Value/(AvgCount/4)) ' "Real Close"
AVGok:
IF ABS (ADavg - ADhyst) > HystLevel then ' If it changed > HystLevel +/-
ADhyst = ((ADavg + 5) / 10) * 10 ' Round ADavg to get new Value
AVGchanged = 1 ' Indicate that Average changed
NoChange:
Value = ADhyst / 10 ' Scale the result down
OverAverage:
It may not have been put in there properly. Can you click the link and see what you get?
From the code, it jumps over the section staring with:
It does not seem to make sense to me.
Thanks. :-)
The label OverAverage is right at the bottom of the code you just posted.
Usually you include the file somewhere around the top of your program. When the program starts from the beginning it eventually reaches the code which is in the include file. If you don't want it to execute the code at that point you must jump over it and that's exactly what's happening here.
Then, when you actually WANT to execute the code from within your main routine or whatever you GOSUB Average, that way it will enter the code after the GOTO OverAverage and execute the code until it hits the RETURN which returns the execution to the place it was called from.
The averaging code is an INCLUDE file.
Save it to a file called "Average_Hyst.pbp".
Put the file in the same folder as your project, or the PBP folder.
Then at the top of the code in post #4, add this line.
INCLUDE "Average_Hyst.pbp"
The GOTO OverAverage line just jumps over the code, making sure execution doesn't "Fall Into" the subroutine without being called by a GOSUB.
Then, change these lines to use the "Value" variable, instead of adval.
ADCIN 0, Value
GOSUB Average
LED = Value * LEDcount ; Determine which LED to light
Edit: Whoops, sorry Henrik.
Took me an hour to get his darn post to go through.
The forums going up and down like an elevator.
Ya beat me to it.
OK, that is what I thought but could not get my head around it. Too many late nights!
Thanks, I will give it a shot and see if it works.
I sure learn a great deal on these forums. I have to start using the LOOKUP command more...very useful!!
Alrighty, I just implemented the code and for the most part it works real well! Thanks!
I still get flickering on a single LED now at some in-between value.
Not sure it this can be gotten rid of and have a nice solid LED. I have these values in:
HystLevel CON 13 ' 7 = .7 of the Least Significant Digit
AvgCount CON 32 ' = Number of samples to average. For best response
FAspread CON 100 ' = Fast Average threshold +/-
