Variable PWM on 2 Channels using software.
I basically have two working routines and am having serious difficulty on the third.
One is a variable PWM on a single coloured LED, which when you push a button, the LED gets brighter and then dimmer. Just like a standard house light dimmer switch.
The Second is a RGB sequence using PWM and three LEDs.
The third i would like to vary the brightness of TWO LEDs at the same time. Same as the first routine just with TWO LEDs.
Now as the PIC16F628A can only handle PWM on one channel at a time, i have tried modifying the RGB sequence to perform this task to no avail. I am thinking i need to do it along the lines of an Array, but to be honest am getting it round my neck.
I have posted the two routines below, along with my attempt which kind of works, but not properly. The LED Dims on one LED but not the other and you can't see the level of dim until you release the switch.
There is a lot more to this full code, but hopefully this will be enqough to explain what i am trying to achieve. Can some offer help please? I have been working on this for weeks and its driving me mad !!
[Fading Single LED]
VariableSolidColour:
PWM onled,bright,10
If FuncSwitch=0 Then
While FuncSwitch = 0
If Flag = 0 Then
If Bright <255 Then Bright = Bright + 1
If bright = 255 Then Gosub flash
EndIf
If Flag = 1 Then
If Bright >0 Then Bright = Bright - 1
EndIf
PWM onled,Bright,10
WEnd
Flag = Flag + 1
EndIf
[/Fading Single LED]
[RGB Sequence]
RGBSequence:
rainbowval=0
While (rainbowval !=255) and (getout=0)
for RGBDelay = 1 to 10
gosub RGBRainbow
next RGBDelay
rainbowval=rainbowval+1
Wend
While rainbowval and (getout=0)
gosub RGBRainbow
next RGBDelay
rainbowval=rainbowval-1
wend
RGBRainbow:
rbg=0
While (rbg<=2) and (getout=0)
section = ((rainbowval + ((rbg * 2)*delta))/ delta) // 6 ' this gives
' what section
' it is in
Select case section
case 0
rbgarray[rbg] = (rainbowval // delta)*6 ' this is how far it
' has gone in its
' section
case 1
rbgarray[rbg] = 255
case 2
rbgarray[rbg] = 255
case 3
rbgarray[rbg] = 255 - ((rainbowval //delta)*6)
case 4
rbgarray[rbg] = 0
case 5
rbgarray[rbg] = 0
case 6 'this one is for pics bad math
rbgarray[rbg] = 0
end select
rbg=rbg+1
wend
Gosub ledpwm
ledPWM:
y=0
While (y<=2) and (getout=0)
Select Case y
Case 0
PWM red, rbgarray[y], 1
Gosub ResetLEDs
Case 1
PWM green, rbgarray[y], 1
Gosub ResetLEDs
case 2
PWM blue, rbgarray[y], 1
Gosub ResetLEDs
End Select
y=y+1
wend
[/RGB Sequence]
[My Attempt]
VariableDualColour:
' PWM onled,Brightx,1
' PWM secondled,brightx,1
Gosub pwmdual
If Flag = 0 Then
EndIf
If Flag = 1 Then
EndIf
gosub pwmdual
WEnd
Flag = Flag + 1
EndIf
PWMDual:
For z = 0 to 1
Select Case z
Case 0
pwm Onled, Bright, 10
case 1
pwm secondled, bright, 10
end select
next
[/My Attempt]
Many thanks for any help,
