Help with multiple ADC inputs
		I'm having some issues turning on more than a single ADC input, Ive been using the code below.
DEFINE ADC_BITS 10 ' A/D number of bits
DEFINE ADC_CLOCK 1 ' Use A/D internal RC clock
DEFINE ADC_SAMPLEUS 50 ' Set sampling time in us
RES1 Var Word ' A/D converter result
RES2 Var Word ' A/D converter result
RES3 Var Word ' A/D converter result
AGAIN:
ADCIN 0, Res1 ' Read Channel 0 data
ADCIN 1, Res2 ' Read Channel 1 data
ADCIN 2, Res3 ' Read Channel 2 data
res1 = res1 /256
res2 = res2 /256
res3 = res3 /256
'Display all 3 ADC results on LCD
Pause 100
goto again
 Now I know im missing some ansel, adcon or something to enable the extra inputs, right now the extra inputs are eratic/off, they dont take readings right.
as long as i stay with ADCIN 0 thers no problem, but I need to take readings on more pins. and am confused on these extra settings, any ideas would be great. also i havent learned to do the fuse settins for freq, brounout, mclre ect, so if possible leave that stuff out of code for right now.
BTW using a 18F4550
		Re: Help with multiple ADC inputs
		Try adding
ADCON2.7 = 1
ADCON1 = %00001100
TRISA = %00000111
		after adding that none of the adc works. let me post the actual code im using not the base code, i will include the code you posted
ADCON2.7 = 1
ADCON1 = %00001100
TRISA = %00000111
TRISD = %00000000 ' PORTD is output
LCDOUT $FE, 1 ' Clear LCD
PAUSE 500 ' Wait 0.5sec for LCD to initialize
SETT Var Word ' A/D converter result in 10bit
READT var word
AGAIN:
ADCIN 0, READT ' Read Channel 0 data
ADCIN 1, SETT ' Read Channel 0 data
ReadT = ReadT / 13 'this may change depending on thermostat
SETT = SETT / 1024 'Output = 0 - 63
readT = (((readT / 10) * 9) / 5) + 33 'Convert ANA0 to Farent.
setT = sett + 40 ' Temp Range will be 40 - 103
LCDOUT $FE, 2
LCDOUT $FE, $80
LCDOUT "Set Temp = ", DEC setT , $DF , "F     "
LCDOUT $FE, $C0
LCDOUT "Temp = ", DEC READT , $DF , "F     "
GOTO AGAIN ' Repeat
		Not sure what is going on with your setup, I do not see the problem.
I dug out a board with an 18F2550 and ran the below code to make sure it works.  I only have the ADC on channels 1 and 2 as I have a LED soldered on channel 2. Other than that it should all be the same.
'<FL_PIC18F2550>'
    '<FL_PBPL>'
    DEFINE OSC 48
     __CONFIG   _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
     __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
     __CONFIG   _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
     __CONFIG   _CONFIG2L, _PWRT_ON_2L & _VREGEN_ON_2L
     __CONFIG   _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
     __CONFIG   _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    CNT VAR BYTE
    ADCON2.7 = 1
    ADCON1 = %00001101
    TRISA = %00000011
    DEFINE ADC_BITS 10
    ADC_0   VAR WORD
    ADC_1   VAR WORD
    START:
    CNT = CNT + 1
    Serout2 PORTC.6, 16572, ["TEST ",DEC3 CNT, $d, $a]
    Serout2 PORTC.6, 16572, ["ADC_0 ",DEC4 ADC_0, $d, $a]
    Serout2 PORTC.6, 16572, ["ADC_1 ",DEC4 ADC_1, $d, $a]
    TOGGLE PORTA.2
    PAUSE 1000
    GOSUB GET_ADC
    GOTO START
    GET_ADC:
    ADCIN 0, ADC_0
    ADCIN 1, ADC_1
		I got it to work by leaving off the adcon.7 code, heres what I am using for 2 ADC, it works great, if I change the adcon.7 it wont even compile
ADCON1 = %10000000
TRISA = %00000011 'PORTA 0&1 is input
READT var word ' A/D converter result in 10bit
AGAIN:
ADCIN 1, SETT ' Read Channel 1 data
		ADCON.7 will not compile because it is a wrong command. You need to use ADCON2.7=1
		sorry I mistyped, I did use adcon2.7, ill try to produce the exact error again and post it.
