My serial to parallel attempt
		I have tried to re-write a serial to parallel program found in John Iovine's  "PIC Microcontroller Book", in the chapter on serial communication.His program was written in PIC basic, but I wanted to re-write and compile in PICbasic Pro.  Nevertheless, even when my program compiled successfully, it did not perform successfully on the circuit board.  I used a pic16F84A, a 74LS164 serial-in, parallel-out shift register, a 32.768 Khz crystal, 8 LEDs and 8 330 ohm resistors.  I have not inserted the code or schematic as yet but will upload these later.  The objective was to send info serially to the 74LS164, which in turn would output the 8 bit number in parallel to 8 LEDs.
		Re: My serial to parallel attempt
		A brief look at my circuit can be found at this link.
http://www.youtube.com/watch?v=XNILnxIycFQ
My code for this project is below, if loaded successfullly.
' serial out interface
'slow program for visual testing interface
'initialize ports
TRISB = 0			'set portb as output port
b0  var byte
pin0 var byte
start:
b0 = 128		'put number 128 ( 1000 0000) into b0
Gosub serial		'output the No. serially to 74ls164
'pause 1000		'wait 1 sec
b0 = 255		'Put No 255 (1111 1111) into b0
'Pause 1000		'wait 1 sec
b0 = 0			'Put No. 0 (0000 0000) into b0
Gosub serial		'output the No. serially to 74LS164
Goto start		'do it again
'serial out routine
serial:
pin0 = portb.7		'bring pin 0 high or low depending
                        'upon bits
Pulsout 1,1		'Bring CLK line high, then low
'pause 100		'same as above
pin0 = portb.6		'same as above
Pulsout 1,1		'same
'Pause 100		'same
pin0 = portb.5
Pulsout 1,1
'pause 100		'optional delay
pin0 = portb.4
Pulsout 1,1
'pause 100
pin0 = portb.3
Pulsout 1,1
'pause 100
pin0 = portb.2
Pulsout 1,1
'pause 100
pin0 = portb.1
Pulsout 1,1
'pause 100
pin0 = portb.0
Pulsout 1,1
'Pause 100
Low 1
		Look at the SHIFTOUT command in the PBP manual.  It does the hard work for you.
		Thanks for the direction and tip.  I have found out a bit more about about sending and receiving serial information using the PIC. Such commands as serout, hserout and even shiftout. My test was to try synchronous data, and to use a clock.  It seems that I could even do away with the 74LS164 and use another PIC chip to receive. That is, a 12F683 could read in some analog voltage, send it out serially and be intercepted by a 16F84, 16F628 or 16F684 and sent out to a 2 or 3 digit 7-segment LED.  It may also be an easier task to use the built-in asynchronous serial transfer.   I will also be looking at this alternative.
		Thanks. I will look at it the first opportunity I get.  My circuit is synchronous transfer, but I will also look at the advantages of asynchronous using other pic commands like serout and serin.   I want to further explore these with the 16F84A, 16F628 and 16F684.
