Writing code for a feedback loop
I'm having some difficulty writing a routine for a feedback loop. What I need to do is read a value taken from the network. Then I adjust the PWM based upon the value. In laymans terms, it would look like this:
IF TEMP > 105 AND TEMP < 170 THEN 'IF TEMP IS IN THE NORMAL RANGE, WE FORCE IT. OUTSIDE NORMAL RANGE, WE DON'T TOUCH IT.
FORCE_FLAG=1 'THE FIRST TIME THIS ROUTINE IS ENTERED
DUTYCYCLE=(170-TEMP/3)+222 'THIS GETS ME IN THE BALLPARK
FORCE_FLAG=0 'ROUTINE HAS BEEN ENTERED SO THE FLAG IS NOW RESET AND
'THIS ROUTINE WON'T BE ENTERED AGAIN UNTIL THE TEMP IS OUTSIDE THE NORMAL RANGE
FORCE_FLAG=1 'THE NEXT TIME THROUGH, WE NEED TO CHECK THE INITIAL ROUTINE
DUTYCYCLE=0 'THE TEMP IS OUTSIDE NORMAL VALUES SO WE DON'T TOUCH IT.
IF FORCE_FLAG=0 THEN 'THE INITAL ROUTINE WAS ENTERED SO NOW WE NEED TO FINE TUNE IT
This is where I'm stuck. Between 105 and 170, the PWM range will be approximately 22 steps (222 at 170 and 244 at 105). In the first routine I got the value close but how do I adjust the PWM signal without over or undershooting the perfect value?
Re: Writing code for a feedback loop
I may be over simplifying it but, if the TEMP value is within the adjustment range of 105 and 170, it seems that the IF/THEN condition would fine tune your PWM signal already.
I also notice the DUTYCYCLE math needed the parentheses moved.
DUTYCYCLE = (170-TEMP)/3 + 222
DUTYCYCLE = 0
