Looping through MyVar.n - will this work?
		Hello all.
I dug around a bit and couldn't find a solid answer.  I'm hoping this is a quick answer from someone.
Can I loop through the bit position in a variable by using another variable to represent the bit position?
For example,
I know I can do this:
MyVar.0 = 1
MyVar.1 = 1
MyVar.2 = 0   ... etc
I want do this:
n=0
MyVar.n = 1
... later in the loop, n is 5, so
MyVar.n = 0
etc.
I've compiled it and PBP doesn't seem to like it.
Much appreciated.
		Re: Looping through MyVar.n - will this work?
kjavrd
			Hello all.
For example,
MyVar.0 = 1
MyVar.1 = 1
MyVar.2 = 0   ... etc
I want do this:
n=0
MyVar.n = 1
MyVar.n = 0
etc.
Much appreciated.
 I had much the same question the other day - only with an I/O port.  I think this will do it:
As always, I stand to be corrected
		I found the answer, as usual thanks to Melanie.
http://www.picbasic.co.uk/forum/show...=2017#post2017
she says.....
1. How can I reference a BIT in a BYTE?
We know that MyByte.0 references Bit 0 of MyByte, all the way up to MyByte.7 referencing Bit 7 of MyByte… but there’s another way of accessing the bits in a Byte (MyVar is a BYTE variable)…
MyByte.0(MyVar)
When MyVar is in the range 0-7, it will access Bits 0-7 of MyByte.
Example to display all eight BITS of a BYTE sequentially, Bit at a time…
For MyVar=0 to 7
MyBit=MyByte.0(MyVar)
LCDOut $FE,1,"Bit ",#MyVar,"=",#MyBit
Pause 2000
Next MyVar
Thanks.  :-)
