Buzzer if object is heavier than a certain weight
I want to start a simple hobby project, but have no idea where to start.
I just want to trigger a buzzer if anything enters an entrance heavier than a certain weight.
It don't have to be accurate, but as cheap as possible.
If someone can please point me in the right direction?
Re: Buzzer if object is heavier than a certain weight
Ok heres some questions for you to answer to help you define the outcomes that you may require
first
1. define the sensor type To measure the weight - assumption person will step on sensor
doing a quick google - check out sensors
http://www.kerrmedical.com/weightsen...mmonitors.aspx
http://www.medicalproductsdirect.com/alprmasmwese.html
simple pressure mat cant measure weight
http://www.jaycar.com.au/productView.asp?ID=LA5131
2. pick an pic which will allow a analog input , most do ,these type of mat produce a voltage relative to a weight so hooking it up is easy enough as most provide details of the interface to most alarms system they support.
get that far and it s a starting point
Thank you very very much, I will do some research on that!!!
What other types of sensors can distinguish between a large object (eg vehicle / human) and a small object, or just ignore the small objects?
What will be the maximum distance for detection?
Sorry for the late response.
About 2 meters
some interesting sensors which may help
http://www.hokuyo-aut.jp/02sensor/
