Problem with PIC basic code *.bas
		I have try to make car robot and have problem with my code need all friend to help.
Pls help to verify why did not work thank
'*  Name    : IR_car3.BAS                                       *
'*  Author  :                                                   *
'*  Notice  : Copyright (c) 2005                                *
'*          : ALL Rights Reserved                               *
'*  Date    : 10/3/2003                                         *
@ DEVICE PIC16F84a, WDT_OFF,PWRT_ON, PROTECT_OFF
TRISA = %00011111
TRISB = %11111111
IRpulse_length var word
xx var Byte
Command	Var	Byte
Device Var Byte
sw_l var PORTB.0
sw_r var PORTB.1
left var PORTA.0    'turn left
right var PORTA.1   'turn right
fwd var PORTA.2    'go
bkd var PORTA.3    'back
n var Byte
n = 0
'pause 150
enable INTERRUPT
START:
    LOW BKD
    HIGH FWD
    PAUSE 150
If sw_l = 0 then
    HIGH BKD
    LOW FWD
    PAUSE 800
    LOW BKD
    LOW FWD
    iF SW_r = 0 THEN
        HIGH BKD
        LOW FWD
        PAUSE 800
        LOW BKD
        LOW FWD
'Ir decoder
PULSIN Portb.2,0,IRpulse_length(0)
IF IRpulse_length(0) = 0 THEN start
for xx =1 to 18
pulsin Portb.2,0,IRpulse_length(xx)
next  xx
disable INTERRUPT
displaybits:
if IRpulse_length(1) < 100 then
Command.bit0 = 0
Else
Command.bit0 = 1
if IRpulse_length(2) < 100 then
Command.bit1 = 0
Else
Command.bit1 = 1
if IRpulse_length(3) < 100 then
Command.bit2 = 0
Else
Command.bit2 = 1
if IRpulse_length(4) < 100 then
Command.bit3 = 0
Else
Command.bit3 = 1
if IRpulse_length(5) < 100 then
Command.bit4 = 0
Else
Command.bit4 = 1
if IRpulse_length(6) < 100 then
Command.bit5 = 0
Else
Command.bit5 = 1
if IRpulse_length(7) < 100 then
Command.bit6 = 0
Else
Command.bit6 = 1
Command.bit7 = 0
Command = Command + 1
If Command = 10 then
Command = 0
Endif
if IRpulse_length(8) < 100 then
Device.bit0 = 0
Else
Device.bit0 = 1
if IRpulse_length(9) < 100 then
Device.bit1 = 0
Else
Device.bit1 = 1
if IRpulse_length(10) < 100 then
Device.bit2 = 0
Else
Device.bit2 = 1
if IRpulse_length(11) < 100 then
Device.bit3 = 0
Else
Device.bit3 = 1
'Device.bit1 = 0
low portb.7
'SEROUT Porta.3,sbaud,[#Device," - ",#Command,13,10]
iF COMMAND = 13 THEN
    high left
    PAUSE 800
RESUME
ENABLE INTERRUPT
'pause  100
goto start
