Math problem that won't work
Why won't this work?
Data6 is a variable that ranges from 0 to 127
Light = (Data6/127)*100
I get 0 from 0-126 and 127 gives me 100.
I had a similar issue with another math problem and I'm guessing they are related. I had to use a lookup table to solve this one and if I can get rid of the lookup table it would save me some code space.
T=((DATA4*9/5)+32)*10
I know you can't use decimal points when multiplying but I think you could multiply by 10 and then use the //10 to get the remainder but in this case I'm just getting 0.
Re: Math problem that won't work
PBP works with integers only.
1/127=0.0079 which will be truncated to 0, 0*100=0
126/127=0.99 which will be truncated to 0, 0*100=0
127/127=1, 1*100=100
Multiply it by 100 first - then divide it by 127.
126*100=12600, 12600/127=99
Obviously it's not perfect because (1*100)/127 will still return 0
What if you multiply/divide by more than 100 to pick up extra decimals?
I'm not making NASA type products here so even if there is a 2 or 3% error, the end user probably wouldn't know. And if they did know, they won't care. That tip worked out great, thanks Henrik.
The more the merrier but you can't have an amount that is greater than a word sized variable. I've found that in most cases you don't need a long to do decent math.
