Thermostat for refrigerator
I wrote code for thermostat, with settings of lower und upper threshold...Work fine, but I can not settings those thresholds under 0.0 'C :( . Under "0.0 'C" (in settings menu, for temp_up & temp_down) on display I have "+655 'C" and minus-button decrease this value ...
Please, can give someone a hand of help ?! Thanks in advance !
@ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
define osc 4
INTCON = 0
include "D:\pbp\alldigital.pbp"
PORTA.7 = 0
TRISA= %00100000
TRISB= %00001111
CMCON= 7 ' Disable comparators
DEFINE LCD_DREG PORTB ' LCD on port B
DEFINE LCD_DBIT 4 ' Data bits B4..B7
DEFINE LCD_RSREG PORTA ' RS on PORTA
DEFINE LCD_RSBIT 0 ' RS on A1
DEFINE LCD_EREG PORTA ' E on PORTA
DEFINE LCD_EBIT 1 ' E on A0
DEFINE LCD_BITS 4 ' LCD 4 bit mode
DEFINE LCD_LINES 2 ' 2 line LCD display
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 50 ' Data Delay (uS)
Temperature Var Word ' Temperature storage
TempC Var Word
Float Var Word
V Var Word ' Var. for display
Sign Var Byte ' +/- sign
DQ Var PORTb.3
Twist Var Bit
Dummy Var Byte
Delay var byte
Mode VAR BYTE
DS18B20_12bit CON %00111111 ' 0,25°C
AlarmUp VAR BIT
AlarmDn VAR BIT
B1 Var Byte ' Byte for Temp_Up calculation
B2 Var Byte ' Byte for Temp_Up calculation
B3 Var Byte
B4 Var Byte
Temp_Up Var Word
Temp_Down Var Word
Read 0, B1 ' Read Temp_Up MSB
Read 1, B2 ' Read Temp_Up LSB
Temp_Up=B1*256+B2 ' Calculate Temp_Up value
Read 2, B3
Read 3, B4
Temp_Down= B3*256+B4 ' Calculate Temp_Down value
PORTA.7 = 0
PORTA.2 = 0 ' Warm Output Low
PORTA.3 = 0 ' Cold Output Low
Mode = 0 ' Temperature display mode
Pause 500
LCDOUT $FE, 1, $FE, $0C ' Clear display, cursor off
Pause 100
' Init Sensor
OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
OWOut DQ, 1, [$CC, $48] ' Start temperature conversion
OWOut DQ, 1, [$CC, $B8]
OWOut DQ, 1, [$CC, $BE]
Pause 50
OWIn DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]
Pause 50
MainLoop:
If PORTB.0=0 then ' Mode switch pressed
Pause 50 ' Debounce
If PORTB.0=0 then MainLoop ' Wait until button is released
Mode=Mode+1 ' Increment mode
If Mode=2 then ' SET Temp_Up
LcdOut $FE, $80, " TEMP_UP : "
LcdOut $FE, $C0, " ", Sign, DEC (Temp_Up / 100), 223,"C "
if portb.1=0 then
Temp_Up=Temp_Up + 100
Gosub Debounce
if portb.2=0 then
Temp_up=Temp_up - 100
Gosub Debounce
EndIf
If Mode=1 then ' SET Temp_Down
LcdOut $FE, $80, " TEMP_DOWN : "
LcdOut $FE, $C0, " ", Sign, DEC (Temp_Down / 100), 223,"C "
if portb.1=0 then
Temp_Down=Temp_Down + 100
Gosub Debounce
if portb.2=0 then
Temp_Down=Temp_Down - 100
Gosub Debounce
EndIf
If Mode > 2 then
LCDOUT $FE, $C0, "END SETTING"
PAUSE 1000
Write 0, Temp_Up / 256 ' TargetTemp MSB
Pause 50
Write 1, Temp_Up MOD 256 ' TargetTemp LSB
Pause 50
Write 2, Temp_Down / 256
Pause 50
Write 3, Temp_Down MOD 256
Pause 50
mode=0
EndIf
If Mode > 0 then Mainloop
Main :
PORTA.7 = 0
if portb.0=0 then Gosub MainLoop
OWOut DQ, 1, [$CC, $44]
Pause 760
WaitLoop:
While not DQ
Wend
Convert_Temp:
If Temperature.15 then
Temperature= ~Temperature +1
Twist = 1
Endif
Dummy = 625 * Temperature
TempC = DIV32 10
TempC = (Temperature & $7FF) >> 4
Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
Temperature = TempC*100 + Float
If Twist then
V= 10000 - Temperature ' 25 C=12500 0 C=10000 -10 C=9000
Twist = 0
V= 10000 + Temperature
EndIf
GoSub SelectSign ' +/blank/- Sign
GoSub DisplayTemp ' Temperature to LCD
Gosub Checking
Goto Main
' SUBROUTINES:
SelectSign:
If v = 10000 then ' Temperature = 0 C.
Sign=" " ' No sign
Else
If v < 10000 then ' <> 0
Sign="-" ' Temperature below 0 C.
Else
Sign="+" ' Temperature above 0 C.
EndIf
EndIf
DisplayTemp:
If V >= 10000 then ' Above 0 C.
Temperature=V-10000
Else
Temperature=10000-V ' Below 0 C.
EndIf
LcdOut $FE, $80, "TEMP : ", Sign," ", DEC (Temperature / 100), ".", DEC1 Temperature dig 1 , 223,"C "
LcdOut $FE, $C0, "DN:",Sign, DEC (Temp_Down / 100), 223, " UP:", Sign, DEC (Temp_Up / 100), 223
Checking:
If temperature < Temp_Down then ' Below Target temperature - Hysteresis
PORTA.2=1 ' Activate Warm Output
if AlarmDn = 0 then
sound porta.7, [80, 150]
low porta.7
alarmDn = 1
alarmDn = 0
Porta.2 = 0
EndIf
If Temperature > Temp_Up then ' Above Target temperature + Hysteresis
PORTA.3=1 ' Activate Cold Output
if AlarmUp = 0 then
sound porta.7, [110, 150]
low porta.7
alarmUp = 1
alarmUp = 0
porta.3 = 0
EndIf
Debounce :
For Delay= 1 to 200
Pause 1
next Delay
END ' Of program
Re: Thermostat for refrigerator
Normally PBP doesn't handle signed values very well, 1-2=255 so that's probably where the problem is comming from. If you're only displaying values then you can use the SDEC modifier in LCDOUT etc statements, it will give you -1 for the above example. This is only for display purposes though, the actual math operations are still treated as unsigned.
What to do. Well, you could switch to LONG variables - these are signed. Or you can apply an offset to all your values so that instead of the value 0 meaning 0 degrees you say that 10000 means 0 degrees. 10001 is 0.1 degrees and 9999 is -0.1 degrees - for example.
I haven't looked very cloesly at your actual code in order to say which would be best.
Thanks for reply ! As usual, I know You are right, but ...
I trying different variants (applying an offset, like v=10000 + temp_up) ...still no results. I will keep trying ...harder !
