Anyone ever decoded CAN on a PIC?
All:
Compressed Alphanumeric Code, or CAN code, allows a 16 bit value to represent 3 characters from the set A-Z, 0-9 and the colon, period and dollar sign symbols.
HEX CAN HEX CAN HEX CAN
0 0 0
640 A 28 A 1 A
C80 B 50 B 2 B
12C0 C 78 C 3 C
1900 D A0 D 4 D
1F40 E C8 E 5 E
2580 F F0 F 6 F
2BC0 G 118 G 7 G
32C0 H 140 H 8 H
3800 I 168 I 9 I
3E40 J 190 J A J
4480 K 1B8 K B K
4B00 L 1E0 L C L
5140 M 208 M D M
5780 N 230 N E N
5DC0 O 258 O F O
6400 P 280 P 10 P
6A40 Q 2A8 Q 11 Q
7080 R 2D0 R 12 R
76C0 S 2F8 S 13 S
7D00 T 320 T 14 T
8340 U 348 U 15 U
8980 V 370 V 16 V
8FC0 W 398 W 17 W
9600 X 3C0 X 18 X
9C40 Y 3E8 Y 19 Y
A280 Z 410 Z 1A Z
A8C0 0 438 0 1B 0
AF00 1 460 1 1C 1
B540 2 488 2 1D 2
BB80 3 4B0 3 1E 3
C1C0 4 4D8 4 1F 4
C800 5 500 5 20 5
CE40 6 528 6 21 6
D480 7 550 7 22 7
DAC0 8 578 8 23 8
E100 9 5A0 9 24 9
E740 : 5C8 : 25 :
ED80 . 5F0 . 26 .
F3C0 $ 618 $ 27 $
Sample Conversions For "EVI"
To convert to CAN code from ASCII, locate the letter in the tables from left to right, and summing the values indicated. For example:
E = 1F40
V = 370
I = 9
22A9
To convert from CAN code to ASCII, start with the left most column and locate the largest value that does not exceed the CAN code value. Subtract the indicated value and repeat using the remainder for the second and last columns. For example, given the value #35A5:
35A5
-3200 H
3A5
-398 W
D M
The CAN code value #35A5 results in the letters HWM.
OK - So, for the really smart ones - can you hint at a structure that can figure that out in PicBasic? I really don't want to load the whole table into memory!!
I need to take in the CAN code, and return the 3-letter result....
TG
Figured out CAN conversion - posting in case anyone ever needs it..
' Read the TracID into the 3 letters represented
16 bits are in SSD1-SSD4:
SSD4= (ssmax[1]>>4)
SSD3= (ssmax[1] & $f)
SSD2= (ssmax[0]>>4)
SSD1= (ssmax[0] & $f)
TracID_D=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1 ' convert to dec
TC1=(TracID_D/1600)
Select Case TC1
case 0
TracID1 = " "
case TC1 < 27 'A-Z
TracID1 = TC1 + 64
case TC1 < 37 '0-9
TracID1 = TC1 + 21
case 37
TracID1 = ":"
case 38
TracID1 = "."
case else
TracID1 = "$"
End Select
t2=TracID_D-(TC1*1600)
TC2=t2/40
Select Case TC2
case 0
TracID2 = " "
case TC2 < 27 'A-Z
TracID2 = TC2 + 64
case TC2 < 37 '0-9
TracID2 = TC2 + 21
case 37
TracID1 = ":"
case 38
TracID1 = "."
case else
TracID1 = "$"
End Select
TC3=t2-(TC2*40)
Select Case TC3
case 0
TracID3 = " "
case TC3 < 27 'A-Z
TracID3 = TC3 + 64
case TC3 < 37 '0-9
TracID3 = TC3 + 21
case 37
TracID1 = ":"
case 38
TracID1 = "."
case else
TracID1 = "$"
End Select
TracID1, TracID2, TracID3 will be the 3 letters..
TG
