Simple READ/WRITE EEPROM is driving me nuts! pls help
This is a stripped down part of a larger program. Eventually I need to collect several temperatures over a period of time, and read them back later, after power-cycling the pic. I simply can't figure out what is going wrong. I have commented the listing at several points to explain what I am doing in this very simple routine. I have used extensive serout2 commands to see exactly what is going on - but they do not help my simple mind at this point. As I have commented in the listing, I can write, and then read back immediately to the on-board EEPROM, and everything works in two identical routines. However, trying the same code another time does not work. I'm sure there are probably postings here that will help, I just have not been able to find any yet. I noticed on this listing that the first read of TempF shows TEMPF as all caps , however that is not the way the actual listing is.
I am using PBP version 2.6a, and a 18f2520. The defines, etc are required for the complete program.
any and all comments will be most appreciated
Ken
'* Name : RD / WRT TEST.BAS *
'* Author : KRS *
'* Date : 7/27/2012 *
'* Version : 1.0 *
'* Notes : USING PBP VERSION 2.60A PIC IS 18F2520 *
'* : I AM USING WEB4ROBOTS SERIAL KEYPAD AND LCD *
'* : REQUIRES DIFFERENT SEROUT2 COMMANDS *
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
OSCTUNE.6 = 1
define OSC 4
OSCCON = %01101110
ADCON1 = %10001011 ' RIGHT JUSTIFY, PORTB ALL DIGITAL
TRISC = %10111000
TRISA = %11111111
TRISB = %00000011
MXSO VAR PORTC.0 ' SERIAL IN
MXCS VAR PORTC.1 ' CHIP SELECT
MXSCLK VAR PORTC.2 ' CLOCK
INT VAR PORTC.5 'Keyboard INT used to signal a key entry
TX var PORTC.6
Rx var PORTC.7
'Allocate MAX6875 Variables
MXTemp var word 'raw data from 6675/type K sensor
TempF var word 'Actual Farenheit temp
TempC var word
Y VAR BYTE
x var byte
Z VAR BYTE
TEMPF1 VAR WORD
TEMPF2 VAR WORD
' web4robots must be set-up first ! ! !
serout2 TX,84,[$FE,$02,3] 'SET BAUD RATE AT 9600
PAUSE 50
SEROUT2 TX,84, [$FE, $0A] 'Ensures that the display is on
pause 150 'Eliminate double key entry
SEROUT2 TX, 84, [$FE, $14] 'Ensures that the screen is cleared
PAUSE 100
SEROUT2 TX, 84, [$FE, $03, 20] 'Sets the brightness (0-250)
PAUSE 100
SEROUT2 TX, 84, [$FE, $04, 10] 'sets contrast (Low number = Hi Contrast)
PAUSE 100
serout2 TX,84,[$FE,$14] 'clear the screen
START:
PAUSE 2000
Y = 0
for x = 1 to 5
WRITE_temp: 'READ THE THERMOCOUPLE AND SAVE IT
MXCS = 0 'Chip select low
shiftin MXSO, MXSCLK, 0, [MXTemp\16] 'read the data to MXTemp
MXCS = 1 'Chip select high
TempC = MXtemp >> 5
TempF = (TempC*18)/10+32
pause 30
' READ THIS TEMPERATURE
SEROUT2 TX,84,[$FE,$0C,0,0,"TEMP= ",dec TEMPF]
PAUSE 3000
SEROUT2 TX,84,[$FE,$14] ' clears the display
PAUSE 50
' NOW WRITE IT TO EEPROM LOCATION IN VARIABLE Y
WRITE Y,WORD TEMPF
' IMMEDIATELY READ IT BACK - - THIS VALUE IS READ CORRECTLY ALL 5 TIMES
READ Y, WORD TEMPF1
SEROUT2 TX,84,[$FE,$0C,1,0,"READ TEMP= ",DEC TEMPF]
PAUSE 30
PAUSE 3000
PAUSE 3
' NOW READ IT BACK AND WRITE TO A DIFFERENT VARIABLE ( TEMPF1)
' THIS READ ALSO WORKS CORRECTLY ALL 5 TIMES
READ Y, WORD TEMPF1
PAUSE 50
SEROUT2 TX,84,[$FE,$0C,0,0,"READ1 TEMPF1= ",DEC TEMPF1]
PAUSE 30
SEROUT2 TX,84,[$FE,$0C,1,0,"X = ",dec x]
PAUSE 20
SEROUT2 TX,84,[$FE,$0C,2,0,"Y = ",dec Y]
PAUSE 3000
pause 30
Y = Y + 1
next x
PAUSE 3000
' NOW TRY TO READ IT AGAIN, USING ANY VARIABLE DOES NOT MATTER , TEMPF1, ETC
' THE ONLY CORRECT READ HERE IS THE LAST ONE, (Y = 4)
'ALL OTHERS ARE INCORRECT - - VERY HIGH VALUES - - 23375, 22860, ETC
Y = 0 'RESET THE EEPROM ADDRESS POINTER TO 0
FOR X = 1 TO 5
READ Y, WORD TEMPF2 ' USING VARIABLE TEMPF2 HERE, ANY OTHER VARIABLES
' DO NOT WORK EITHER
PAUSE 50
SEROUT2 TX,84,[$FE,$0C,0,0,"READ2 TEMPF2= ",DEC TEMPF2]
PAUSE 30
PAUSE 30
PAUSE 2000
pause 30
Y = Y + 1
next x
DONE:
PAUSE 50
SEROUT2 TX,84,[$FE,$0C,2,0,"DONE"]
GOTO DONE
Re: Simple READ/WRITE EEPROM is driving me nuts! pls help
At a quick scan I see you are writing a word to the eeprom which = 2 bytes, yet you are only increasing your pointer by 1, I think you need to change it to y=y+2
Thanks for looking Aerostar, but that does not seem to be the problem.
First I write 5 temperature values from the thermocouple in succession, and read each back immediately after it is written.
Next, I use the for next loop, incrementing one at a time, and that works.
It is the last for next loop, identical to the previous one, that does not work.
Still have not figured it out
Ken
ps I did try incrementing by two to no avail
Ken,
Make sure you change BOTH of the "Y=Y+1" statements to "Y=Y+2"
I have verified your code works if you change both. Here is my version of your code. I've trimmed it down, modified the output methods, and generated the temps without the ADC. But your will notice all the WRITE and READ statements are the same. I output the values in hex, which allowed be to then read the EEPROM as an additional way to verify the data.
TEMPF VAR WORD
TEMPC VAR WORD
Y VAR BYTE
X VAR BYTE
Z VAR BYTE
TEMPF1 VAR WORD
TEMPF2 VAR WORD
START:
PAUSE 2000
Y = 0
for x = 1 to 5
TempC = 1 << Y
LCDOUT $FE, $80, HEX4 TempF
pause 30
HSEROUT ["TEMP= ",HEX4 TEMPF, 13]
WRITE Y,WORD TEMPF
READ Y, WORD TEMPF1
HSEROUT ["READ TEMP= ",HEX4 TEMPF, 13]
READ Y, WORD TEMPF1
HSEROUT ["READ1 TEMPF1= ",HEX4 TEMPF1, 13]
LCDOUT $FE, $C0,"X = ",dec x
LCDOUT " Y = ",dec Y
Y = Y + 2
next x
PAUSE 3000
HSEROUT ["-----------------------------", 13]
FOR X = 1 TO 5
HSEROUT ["READ2 TEMPF2= ",HEX4 TEMPF2,13]
Y = Y + 2
next x
HSEROUT ["Done", 13]
DONE:
GOTO DONE
Forgot to post the output:
TEMP= 0021
READ TEMP= 0021
READ1 TEMPF1= 0021
TEMP= 0027
READ TEMP= 0027
READ1 TEMPF1= 0027
TEMP= 003C
READ TEMP= 003C
READ1 TEMPF1= 003C
TEMP= 0093
READ TEMP= 0093
READ1 TEMPF1= 0093
TEMP= 01EC
READ TEMP= 01EC
READ1 TEMPF1= 01EC
READ2 TEMPF2= 0021
READ2 TEMPF2= 0027
READ2 TEMPF2= 003C
READ2 TEMPF2= 0093
READ2 TEMPF2= 01EC
Done
SreveB
Thanks so much. That was my problem. Actually, I thought that I should add 2 each time, but for some reason stuck with only one. You are correct, when I tried adding 2 originally , it was only to one of the sections. Sometimes I guess I should stay in bed longer.
Thanks again
Ken
