LCD error. letters are shifting each water valve is ON
hello friends. sorry for bad english.
i have a system controled by 16f877 and output relays. when 24V water relay is active, letters on 4x20 LCD are shifting one character to left. sometimes also system is reset.
if i connect the valve directly to the 230 v, the valve is no connection to the board or anything else; i have the same problem. it is possible transmissed an electronic magnetic area. how can i solve this problem. thank you.
Re: LCD error. letters are shifting each water valve is ON
Is the board running from batteries or mains? Is the board grounded?
yes all the -'s and grounds are together and grounded. board running power supply 230v to 24v.
What is the power supply like? Do you have plenty of capacitors?
Maybe post the schematic schematic.
here is power supply:
http://static4.tme.eu/katalog_pics/8...b5/dr-4524.jpg
the pic and LCD is feeded by two 78l05cv
Yes, it is possible. I sometimes have this problem around welders and plasma cutters. The solutions range from good grounding to putting the MCU in a metal enclosure ( think Faraday cage ).
thank you friend for your help. i am working on it.
LCD ": This full-fledged, large-character liquid crystal display per-Vides you. Water budgeting: Each program can be independently adjusted to more or less water power the script is the problem drive, and all other operational water valve.
I don't found such type of error in the LCD...:p
