Maths advise needed
		My readings from an analog sensor go from 724 to 3604. These valid readings measure angle of 0 - 90 degrees. My initial code is the following:
                                        If Value<724 then
                                                Value=0 : Dummy=0 : Goto Jump4 : Endif
                                        Value=Value-724
Jump4:
                                        Dummy=Value*9
                                        Angle=Dummy/288
                                        Temp=(Dummy*10)/288
                                        Angle2=Temp DIG 0
 I want to display increments of 0.1 but the problem is that it works fine upto the reading of - 6552 (in Dummy variable) as readings after it goes beyond the 16 bit limit.
So as a result
Temp=(Dummy*10)/288
  starts overflowing and results after the decimal digit stored in Angle2 start getting messed up. Anyone has any idea on how to deal with this situation please. Thanks
Re: Maths advise needed
		Problem Sorted. Taking the remainder and multiplying it by 10 and dividing again. :)
