Hello everyone, I'm having trouble making my program work. I'm using DT interrupts to measure the duration of a servo pulse using CCP interrupts.
The interrupt routine works as expected but it doesn't return to the Main program, I'm missing something. Any input is appreciated.
#config
__config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
#endconfig
define OSC 8
Include "modedefs.bas"
INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
INT_Handler CCP1_INT, _pulsedata, PBP, yes
@ INT_ENABLE INT_INT ; enable external (INT) interrupts
GPIO = 000000
TRISIO = 000101
ANSEL = 000000
CMCON0 = 000111
OSCCON = 110000 '8MHZ
PIE1 = 100000
INTCON = 010000
T1CON = 000001 'no prescaler
CCP1CON = 000101 'rising edge CCP
led var GPIO.5
wsave VAR BYTE $20 SYSTEM ' location for W if in bank0
pulse var word 'received pulse width
clear
toggle led
GOTO Main
pulsedata:
if CCP1CON.0 = 0 then
pulse.lowbyte = TMR1L
pulse.highbyte = TMR1H
' serout 4,N9600,[#pulse,13] 'for testing
CCP1CON.0 = 1 'rising edge CCP
TMR1L = 0
TMR1H = 0
CCP1CON.0 = 0 'falling edge
@ INT_RETURN
