My Head Hurts with Tables, Lookup, EXT etc etc
After some general guidance and ideas here.
I have a program which uses 255 parameters as an index to a table.
These parameters need to lead me to an address in a table which is made up of 3 hex bytes and a 3 character string.
Something like
0 = $12,$34,$44,"VOL"
1 = $22,$F4,$40,"AMP"
2 = $01,$57,$13,"SOC"
Each of the 255 parameters has a different set of values.
I would like a big list/table/memory area with all my data in it but i'm very confused about which is best to use. Lookup, Lookup2, EXT, Eeprom :?
I'm working with a 18F2620 Pic and Pbp 3.01
Thanks Peter
Re: My Head Hurts with Tables, Lookup, EXT etc etc
Peter, I would use eeprom.
Just load all your hex values with
EEPROM 0,[$12,$34,$44,$22,$F4,$40,$01,$57,$13,.............]
Then to load the value into a byte variable use read instruction.
READ index * 3 , byte_value
Cheers
Al.
