PBP3 Support HPWM on CCP3/CCP4 (16F1825)?
I saw a post from Bruce in 2005 that says the HPWM command only works on CCP1 & CCP2, but when I look inside the PBP3 version of pbppi14e.lib it looks like it could work for CCPs higher than 2 - is that true? I would dearly love to use the HPWM command rather than load all of the individual registers which the code below is an example (and it doesn't seem to work - I hooked up an LED to pin 11 (RA2) and its only dimly lit).
' Initialization
DEFINE OSC 20 ' Set oscillator 20Mhz
' Device Fuses
' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
__config _CONFIG1, _FOSC_HS & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
__config _CONFIG2, _LVP_OFF
DEFINE CCP3_REG PORTA
DEFINE CCP3_BIT 2
ANSELA = %00000000 ' Digital only (PortA)
ANSELC = %00000000 ' Digital only (PortC)
ADCON1 = $0F
TRISA = %00000000 ' Make all pins on PortA output
TRISC = %00000000 ' Make all pins on PortC output
DUTY3 var word
' Set CCP modules to PWM mode
CCP3CON = %00001100 ' Mode select = PWM
PR2 = $FF '255
T2CON = %00000110 ' TMR2 on 1:!6 prescale
DUTY3 = 512
CCP3CON.4 = DUTY3.0
CCP3CON.5 = DUTY3.1
CCPR3L = DUTY3 >> 2
lblLoop:
goto lblLoop
Can anyone help me out with the PIC16F1825 and getting HPWM to work? Ideally, I'd just like to do this:
HPWM 3, 127, 20000
