Hi
Does anyone know if you should use additional parameters
to use Xin, Xout in Europe where 50hz is used compared to the US where 60hz is used
Looking to the X-10 spec there should be a diffeence in handling timings
Walter
Hi
Walter
Hi Walter,
As far as Xin is concerned, whether your environment is 50 Hz or 60 Hz makes absolutely no difference. For Xout too, you could run into trouble only if your transmitter and the receiver(s) are on different phases of the mains. If both are on the same mains phase, you will have no trouble with 50 Hz.
Anand Dhuru
