HSERIN + interrupt
Hi everyone,
I was wondering if anyone can enlighten me in achieving my application in mind. I want to receive data from pc with in the following format "A123", B"10", "C5"
where A, B and C is the start data letter and after it are numeric values ranging from 1-255. I did a little research, and mostly I found HSERIN command being used ex.(hserin 1000, _WaitTimeOut, [str rbuffer\5\13]). but not really sure how I can incorporate what I have so far.
The following code (from Mr_e) is what I'm using right now, but I need to incorporate a string filtering for incoming data like "A123".
Include "modedefs.bas"
DEFINE osc 20 ' We're using a 4 MHz oscillator
' Define ADCIN parameters
Define ADC_BITS 8 ' Set number of bits in result
adval Var Byte ' Create adval to store result
i Var Byte ' For-loop variable
position Var Byte ' LED position variable
bright1 Var Byte ' Brightness variable
' PORT setting
TRISA = 000001 ' Set PORTA to all input
ADCON1 = 000010 ' Set PORTA analog and right justify result
TRISB=000000
TRISD=000000
TRISC=000000 ' RC.7 => USART RX pin set to input
' all other pin set to output
TRISB=0 ' RB<7:0> set to output
' USART setting
' Since we will not use HSERIN/HSEROUT, we must
' write directly to internal PIC register
TXSTA=$24 ' enable transmit and SPBRGH=1
RCSTA=$90 ' Enable USART and continuous receive
SPBRG=129 ' BAUD RATE = 9600 BAUDS
' Interrupt definition
PIE1.5 =1 ' enable USART receive interrupt
INTCON.6 =1 ' enable peripheral interrupt
' Alias definition
RCIF var PIR1.5 ' receiver interrupt
StatusLED var PORTB.2 ' the LED who show a 'running process'
' Variable definition
Delay var word '
DataIn var byte ' use to store RCREG content
Discard var byte ' use to erase RCREG register
cntr var byte
cntr = 1
' Hardware/software initialisation
PORTB=0 ' clear PORTB
PORTC=0
PORTD=0
on interrupt goto USARTInterrupt
PAUSE 500 ' Wait .5 second
loop1:
ADCIN 0, adval ' Store ADC value to adval
Hserout["Data recieve:",adval,13]
GOTO loop1 ' Do it forever
disable interrupt
USARTInterrupt:
' Here's the interrupt routine who will make the user
' much happy by giving him the feeling to have the
' control on the machine when the status of the user
' LED will change
RCSTA=0 ' Disable serial port AND
' clear possible error (FERR,OERR)
datain=RCREG ' Get data
while RCif ' wait untill the RCREG is empty
discard=RCREG ' by reading it and store result in a
wend ' don't care variable
select case datain ' What to do with that data???
case "1" ' User selection = 1
PortB.0 = 1
case "2" ' User selection =2
PortB.0 = 0
'------------------------------1---------------------------------
end select
RCSTA=$90 ' Re-enable the serial PORT AND
resume ' get out of here
enable interrupt
Thanks in advance,
tacbanon
