Serial Communication Problem
Hello, I have been wrestling with this for days and thought I'd see if anyone could tell me what I'm doing wrong. I've Googled, gone through some excellent intro PIC books and read the forum here. The closest info I've found is here under the "serial string parsing" thread by billybobbins.
To give you a picture of the end product:
I am putting together a program that does four things: 1) Except a serial data stream of up to 40 bytes long, 2) execute commands based on data from the data stream, 3) re-transmit the data stream (nothing added or changed), and 4) count pulses from an encoder using an interrupt.
My problem is with 1). For the life of me, I cannot get read a stream of serial data as I'd like. I'm trying to create a loop that looks for serial data coming in, reads and stores it into a variable array if any is present and goes onto to perform another function briefly before going back into the original loop.
I'm in a Catch 22. If I don't use a timeout in the serin command, the program does nothing until data comes in, but when it comes in I have all of the bytes regardless of the size. If I do use a timeout either I get junk or a varying portion of the original data.
My test data is sent via hyperterminal at 2400 baud 8N1. This is sent as a data file (notepad txt).
Test data stream is: A00gfhgd00CR+
where the + is used to identify the end of the stream. Eventually the baud will be 9600 and a line feed will be used to denote the end of a stream, just can't simulate a line feed in notepad.
Here is the code with the results:
All code has the following:
include "modedefs.bas"
Trisb = %00000000
Trisc = %01000000
Portb = %00000000
Portc = %00000000
a var byte
b var byte
c var byte
d var byte
RX var byte[40]
TX var byte[40]
i var byte
dSize var byte
f var byte
PDA var byte
InCheck var byte
Yes, I have a few extra variables I'm not using in the current program.
A) Using a for loop and a timeout
serin portc.7, T2400, 100, LED, RX[0]
If RX[0] != 0 Then ReadPDA
goto LED
ReadPDA:
For i = 1 to 40
serin portc.7, T2400, RX[i]
If RX[i] = "+" Then DataOut
Next
goto Error 'DataEnd
LED:
portb.0 = 1
pause 10
portb.0 = 0
pause 10
PDA = 0
goto Main
DataOut:
for d = 0 to i
serout portc.6, T2400, [RX[d]]
next
serout portc.6, T2400, [10, 13]
goto Main
Error:
serout portc.6, T2400, ["Error"]
goto Main
And the results for five streams sent are:
0gfhgd00CR+
A00gfhgd00CR+
˜gfhgd00CR+
A00gfhgd00CR+
A00gfhgd00CR+
Okay, not bad, but the first run didn't catch the A0 and the third not only lost the A00 but thought it saw a y with two dots over it instead.
B) Using a while loop and a timeout
serin portc.7, T2400, 1, LED, RX[0]
'pause 1
'If RX[0] = 0 Then LED
goto LED ' ReadPDA 'Error
LED:
portb.0 = 1
pause 10
portb.0 = 0
pause 10
PDA = 0
goto Main
ReadPDA:
counter = 1
while counter != 40 and RX[counter] != "+"
serin portc.7,T2400, RX[counter]
'if RX[counter] = 0 Then LED
'pause 1
counter = counter+1
Wend
If counter = 40 then Error
goto DataOut
DataOut:
for i = 0 to counter
serout portc.6, T2400, [RX[i]]
next
goto Main
Error:
serout portc.6, T2400, ["Error", 10, 13]
goto Main
00gfhgd00CR++
: fhgd00CR++
‚þ0gfhgd00+
ó0gfhgd00+
Óöfhgd00CR+
Again, if I remove the timeout, the data is perfect but the program doesn't move. I've seen some code with hserin and serin2, but I haven't played with those commands and haven't seen an advantage in using them in this application over serin, at least yet.
Any help or advice is greatly appreciated! Thanks!
hardware UART is the way to go.
Some advice. Always use a hardware UART when you can.
I do bullet proof comms using an asm routine and a harware UART. However, if I had a small program and I didn't want to write an assembly interrupt service routine then I would simple poll the interrupt bit. This bit will set whenever a character has come in. It will clear when you remove the character.
So what chip are you using? Does it have a UART? Can you use it?
Hope this helps,
Joe.
Replacing the clear command?
Steve,
Thank you for the code, it worked beautifully. I did notice that moving the clear command down to the very bottom right before the 'goto main' worked better. I think the data came in so fast that if the timing were off I missed some data streams.
I have a question regarding the clear command. I understand it completely clears the ram which prevents a constant repeating loop of a single data input stream. Is there another way to specifically clear or erase whatever register or ram location the USART uses? I ask because I am running several if then statements that require checking the status of certain variables and if I use the clear command, I lose the original status/data in those variables.
I've tried using RCIF = 0 and RCREG = 0 to no avail. I've also tried the ERASECODE $FAEh to clear the RCREG register, but this command doesn't work in PicBasic Pro with the 18F2525 chip I'm using. Any suggestions?
Again, thanks again for the code, I've been playing with it all day, making mistakes, gaining victories and generally learning a lot in the process.
