Re: HSEROUT at Quarter Rate!
what crystal are you driving the PIC with? I notice you have the PLL enabled which will multiply the crystal freq. by 4 times. You have declared the operating frequency as 8 Mhz. If you have set the internal frequency as 8 Mhz then you are generating 24 Mhz. I would check your settings....
Thanks Dave,
I am currenty using the internal osc, as set by CONFIG FOSC = INTIO1 and it should be running at 8MHz by the OSCCON=%01100000 configs. In regards to the PLL, by switching it on - by either the PLLCFG or OSCTUNE, it enables the HSEROUT command to operate at the correct baud, but this results in the rest of the pic running at 4 times...
Gitchie, That is because you have declared to PBP that you are running the code @ 8 Mhz. by the statement:
define OSC 8 ' Internal OSC runs at 8MHz
This statement tells PBP to scale all timing statements like PAUSE and the like to use an 8 Mhz. oscillator. You should be setting the DEFINE statement to 32 Mhz. which is the frequency that the processor is actually being clocked at.
That's correct, but then the hserout runs at quarter speed... For the moment, I've set the baud to 9600 and will run it at 2400...
Don't you understand? Just set the baudrate to the desired rate and set the DEFINE OSC 32. Everything will work correctly.....
Thanks for your replays Dave,
But it was a typographical error with the HSER2 defines... I had HSER_BAUD2 1200 when it should have been HSER2_BAUD 1200
I was hunting for an OSC problem also
Cheers and thanks again for your suggestions
