pulsin is not getting the next part of wave
Hi guys , well this one has got me thinking , and i am not sure how i may get around it , so a bit of advise on the code would be good
IR data train is as follows
seq is normally high , low for 9ms ,high for 4.5ms, low for 560us , high for data etc ,etc then at end it goes low for 9ms , high for 2.5ms, low for 560us , high for etc etc for 2nd key data block seq , and then repeats entire IR train
the problem is i need to measure duration of low of 9ms , then the high duration of 4.5ms
the high duration length ( 4.5ms or 2.5ms ) after the low 9ms determined if its the 1st or 2nd key within the same pulse also if its blank repeat of key 1
the first Pulsin command gets the pulse length of 9ms ok , but the 2nd pulsin command will not measure the high duration until the next high going pulse.
any suggestions on how to get the length of both the 9ms low and then the high 4.5ms pulse
The 2nd pulsin command as shown below is not working as required
cheers
Sheldon
leader var word
leader1 var word
PULSIN GPIO.0,0,Leader ' leader pulse is ~9mS low-going on port 0
IF Leader < 850 tHEN main
pulsin GPIO.0,1,Leader1 ' check for 1stkey seq only no repeat headers
if leader1 < 300 then Main ' if high for < 300 (2.4ms then its the 2nkey)
Re: pulsin is not getting the next part of wave
The second Pulsin misses the high portion of the pulse because it "trigs" on a low to high to transition - in this case the same transition that ends the first Pulsin - so by the time the second Pulsin starts looking for a transition the transition have already occured.
Here's a more "manual" aproach which may work:
HighCount VAR WORD
LowCount VAR WORD
HighCount = 0
LowCount = 0
While GPIO.0 = 1 : WEND ' Wait for falling edge
While GPIO.0 = 0 ' Increment count while input is low
LowCount = LowCount + 1
WEND
While GPIO.0 = 1 ' Increment count while input is high
HighCount = HighCount + 1
Wend
The actual resolution obviosuly depends on the oscialltor speed etc but it shouldn't be hard to figure out how many "counts" equals one ms.
i have gone around the problem by just looking for correct value of the high pause duration as i know if signal is valid and correct should always work
' PULSIN GPIO.0,1,Leader ' leader pulse is high going on port 0
' IF Leader < 400 tHEN main ' look for 4,5ms high pulse below 400ms then its 2nd key area pulse or data/ address bits
' if leader > 480 then main ' above 480 then its no sig
I know from what i can see here that there is no easy way to both measure a pulse and then it next immediate rising or falling going pulse , am i correct in this ???
Maybe not using pulsin,but you could always use hardware capture if the pic has it.
With Pulsin the short answer is no.
Using the Timer 1 Gate will be much more easier ifyour PIC supports it.
Also controlling the Interrupt Edge on PB0 in combination with a timer (0 or 1) will also help you on this.
The edge is set in the Option Register, bit 6 on most PICs.
Did you try the snippet I posted in the first reply? I think it's pretty straight forward and I think it's pretty much the way that pulsin works "behind the scenes" except that doing this way "trigs" on level and not on transition.
If it doesn't work for whatever reason there are several other ways, some of which other members have outlined here but in order to be able to give you a good advice things like which chip you're using and at what frequency you're running it would be good to know. Not to mention what kind of resolution you actually NEED.
Solution is pretty simple:
leader var word
leader1 var word
RCTIME GPIO.0,1,Leader1 ' check for 1stkey seq only no repeat headers
may be you could consider the IF condition takes few µs ... to be verified, because your time unit is 10µs !
That's all !
it does have PWM , but not tried it as yet , still not sure it would pickup and measure the low to high to low to high cycle and give a measurement for both duration
if only a pulsin "Mark 2" would do this
Thanks guys ,
Both the RCTIME and counter solutions work , as well as my temp get around.
I was not aware of the RCTIME command ,thanks for that
because the times being measured are so long at this point in the signal (IR input) , is not a big timing issue for how it is checked using the if command etc
cheers
Sheldon
