Hello,
I have a projekt, were I have to divide the current Controller into two parts:
The first part is the main Controller with the most parts on it,
the second part is a little display and some buttons several meters away.
I use a I2C-interface on both controllers.
I change the existing LCDOUT-commands into I2CWRITE-commands...
First I noticed, the I2CWRITE-command doesn't support the extensions like SEROUT2 (DEC, BIN...). :-(
And I think, the hole I2C-part is solved in software. Is there any way in PBP to use the hardware in the SSP ? (on the display-controller I programmed the slave-Mode interrupt-driven by using the hardware...)
