Trouble with LCD 2x8 and sequential display of values
Hello !
I try to build one volt/termometer with 16F684 and 2x8 characters display. I wrote the code, all works ...fine, the "IN" temperature is shown for 8 seconds, the "OUT" temperature for next 8 seconds, and so on, and so on (the voltage is on second line permanent)....
BUT : sometimes, the value of temperature "jump" to "0.0 'C", especially when the temperature decreases ?! I really don't understand why :( . I made many changes in "pause", in "Define LCD_COMMANDUS 2000" and "Define LCD_DATAUS 50" , I added/removed " WaitLoop1: While not DQ1 : Wend" , but without results...
Any clue ? Thanks in advance !
This is "the big part" of my code :
Main :
Gosub Get_Vbatt ' make a new measure
TmpW = Vbatt * Vfs ' AD * 20480
TmpW = Div32 1024 '(AD * 20480) / 1024
Gosub char_batt
LcdOut $FE, $c0, symb ," ", dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2, " V"
Gosub StartTimer
While seconds =< 8
Part1:
' Start temp.conv.Sensor1
OWOut DQ1, 1, [$CC, $44]
OWOut DQ1, 1, [$CC, $BE]
OWIn DQ1, 2, [temperature1.byte0, temperature1.byte1]
If Temperature1.15 then
Temperature1= ~Temperature1 +1
Twist1 = 1
Endif
Dummy1 = 625 * Temperature1
TempC1 = DIV32 10
TempC1 = (Temperature1 & $7FF) >> 4
Float1 = ((Temperature1.Lowbyte & $0F ) * 25 )>>2
Temperature1 = TempC1*100 + Float1
If Twist1 then
V1= 10000 - Temperature1
Twist1 = 0
V1= 10000 + Temperature1
EndIf
If V1 >= 10000 then
Temperature1=V1-10000
Temperature1=10000-V1
EndIf
GoSub SelectSign
If (temperature1/100) =>10 then
LcdOut $FE, $80, "I:", Sign1, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 0
LcdOut $FE, $80, "I:", Sign1, $14, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 0
Endif
Pause 500
Wend
While seconds >= 9 and seconds =< 17
Part2 :
OWOut DQ2, 1, [$CC, $44]
OWOut DQ2, 1, [$CC, $BE]
OWIn DQ2, 2, [temperature2.byte0, temperature2.byte1]
If Temperature2.15 then
Temperature2= ~Temperature2 +1
Twist2 = 1
Endif
Dummy2 = 625 * Temperature2
TempC2 = DIV32 10
TempC2 = (Temperature2 & $7FF) >> 4
Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
Temperature2 = TempC2*100 + Float2
If Twist2 then
V2= 10000 - Temperature2
Twist2 = 0
V2= 10000 + Temperature2
EndIf
If V2 >= 10000 then
Temperature2=V2-10000
Temperature2=10000-V2
EndIf
GoSub SelectSign
If (temperature2/100) =>10 then
LcdOut $FE, $80, "O:", Sign2, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 0
LcdOut $FE, $80, "O:", Sign2, $14, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 0
Endif
Pause 500
Wend
Gosub ResetTime
Goto Main
I have in code "include elapsed.bas" of course...The internal osc is set to 4 MHz.
2 Attachment(s)
Re: Trouble with LCD 2x8 and sequential display of values
Even in Proteus I see this trouble, if "Out" temperature decreases verry fast ...
(Just remove final extension of files)
...or another way to display sequential values of temperature(s), while - on second line- display the voltage ?!
Have someone another ideea ? Thanks !
fratello
... BUT : sometimes, the value of temperature "jump" to "0.0 'C", ...
I have in code "include elapsed.bas" ...
1-Wire and interrupts don't get along very well together.
1-Wire has some pretty strict timing requirements, and interrupts like to mess that up.
You can get good readings, but you have to plan on bad data occasionally.
Which means verifying the CRC, and checking for all 0's in the packet. The CRC will pass (incorrectly) with all 0's
You can use the CRC routines from Tom Estes ... http://www.picbasic.co.uk/forum/showthread.php?t=1672
If the CRC fails, just go back and read the temperature again, no need to do another conversion.
That of course means you need to read the sensor as a Packet, instead of individual variables.
You also need to wait for the conversion to complete, either by PAUSE'ING the required amount of time, or polling the busy bit.
Currently, you are not waiting at all after a conversion command.
Thank You for support !
...it's another way to do this ?
I don't think I have enough space for adding something like CRC routines in my code (using 16F684)...
How about just throw away values that are outside of expected ranges? Like take a running average, and if the temp is way off, disregard it. That way, it can still be 0 deg C, but only if its close to the average temp.
Thank you all for support !
Since the "timming" it's not so important , I made this change :
Pause 800 ; because DS18B20 need 750 ms for conversion
Twist1 = 1
Endif
...and the display works fine now...despite the decrease of speed in display the changes of temperatures.
I rushed... still have, from time to time, "0.0 'c" on display, ONLY for sensor on DQ2 (out sensor) .... :( ....
fratello
Why not you poll the busy bit, instead of the Pause 800 statment?
I don't know your application, but you can also disable interrupts before the 1-wire stuff, and then enable them again.
gadelhas
Thanks for help ! How can I make this ? The most part of code it's in post #1...
fratello
Can you put the code of your interrupts stuff, because i don't see it in the code of the post #1
I use just :
"Include "Elapsed.bas"" ; for counting seconds
without other interrupts...
fratello
I use just :
I believe that Elapsed.bas uses Timer 1, maybe Darrel can correct me, if so, do this
@ INT_DISABLE TMR1_INT
'1 wire stuff
@ INT_ENABLE TMR1_INT
Probabily the acurracy of the elapsed.bas would be affected.
I think I made some mistakes ... :( ...
Can you attache the files? ( your code and elapsed.bas)
The code is in post #1 ; this is the "header" :
@ DEVICE PIC16F684, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_ON, PROTECT_ON
TRISA= %00010000
TRISC= %00110000
CMCON0 = %00000111 ' Disable analog comparators.
VRCON = %00000000 ' Disable Comparator Voltage Reference
ANSEL = %00010000 ' Set pin (AN2) to analog input, the rest to digital
ADCON0 = %10001101 ' Set up A/D converter - Right Just., VDD REF., CH 3, ON
ADCON1 = %00110000 ' Set up A/D Converter clock source to internal RC
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
DEFINE ADC_SAMPLEUS 50
DEFINE LCD_DREG PORTC ' LCD on port c
DEFINE LCD_DBIT 0 ' Data bits C0..C3
DEFINE LCD_RSREG PORTA ' RS on PORTA
DEFINE LCD_RSBIT 1 ' RS on A1
DEFINE LCD_EREG PORTA ' E on PORTA
DEFINE LCD_EBIT 2 ' E on A2
DEFINE LCD_BITS 4 ' LCD 4 bit mode
DEFINE LCD_LINES 2 ' 2 line LCD display
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 50 ' Data Delay (uS)
Temperature1 Var Word
Temperature2 Var Word
TempC1 Var Word
TempC2 Var Word
Float1 Var Word
Float2 Var Word
Sign1 Var Byte
Sign2 Var Byte
DQ1 Var PORTC.5 ' OUT SENSOR
DQ2 Var PORTC.4 ' IN SENSOR
Twist1 Var Bit
Dummy1 Var Byte
V1 Var Word
Twist2 Var Bit
Dummy2 Var Byte
V2 Var Word
symb Var Byte
Vfs con 20480 ' 20,480v
K16 con 61441 ' coefficiente filtro 15/16
Vbatt Var Word ' Vbatt filtrato
TmpW Var Word
Acc_Vbatt Var Word ' accumulatore Vbatt filtrato * 16
batt Var Word
DS18B20_1_12bit CON %01111111 ' 750ms, 0.0625°C (default)
DS18B20_2_12bit CON %01111111 ' 750ms, 0.0625°C (default)
LCDOUT 254,64,4,10,4,0,0,0,0,0 ' Cust Char #0 ; http://www.darreltaylor.com/files/CustChar.htm
LCDOUT 254,72,10,31,17,17,17,17,31,0 ' Cust Char #1
LCDOUT 254,80,10,31,17,17,17,31,31,0 ' Cust Char #2
LCDOUT 254,88,10,31,17,17,31,31,31,0 ' Cust Char #3
LCDOUT 254,96,10,31,17,31,31,31,31,0 ' Cust Char #4
LCDOUT 254,104,10,31,31,31,31,31,31,0 ' Cust Char #5
LCDOUT 254,112,15,3,5,9,16,16,16,0 ' Cust Char #6
LCDOUT 254,120,1,1,1,18,20,24,30,0 ' Cust Char #7
include "Elapsed.bas"
Twist1 = 0
Twist2 = 0
Pause 5000
LcdOut $FE, $80," TERMO "
LcdOut $FE, $C0," VOLT "
PAUSE 3000
LCDOUT $FE, 1, $FE, $0C ' Clear display, cursor off
Pause 200
;Init Sensor 1
OWOUT DQ1, 1, [$CC, $4E, 0, 0, DS18B20_1_12bit]
OWOut DQ1, 1, [$CC, $48] ' Start temperature conversion
OWOut DQ1, 1, [$CC, $B8]
Pause 50
Pause 50
;Init Sensor 2
OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_2_12bit]
OWOut DQ2, 1, [$CC, $48] ' Start temperature conversion
OWOut DQ2, 1, [$CC, $B8]
Pause 50
Pause 50
More about "Elapsed.bas" (credits to Mr.Darrel !) here : http://www.picbasic.co.uk/forum/show...7473#post17473
Thanks again for support !
I copied your code, and i can not see that error, however, instead of the;
'1 wire stuff
try this;
T1CON.0 = 0 ; Turn OFF Timer1
'1 wire stuff
T1CON.0 = 1 ; Turn ON Timer1
I tried this way, but...the timer stop counting (so, I can't display 5 sec. IN and 5 sec. OUT) and the reading of sensor(s) it's not continous....like in my "original" code :( ...
I want to read permanent the sensors (for sensing the variation of temperatures) and display the temperature, 5 seconds from first sensor, the next 5 seconds from second sensor, so on, so on ....
Otherwise I can write the code like this :
" display temperature 1
pause 5000
display temperature 2
pause 5000
goto loop "
which is not a good option ...
2 Attachment(s)
fratello,
Try this hex file.
It uses elapsed.bas, adds CRC checking and error correction, while only using 1375 WORDs.
Yours was 1871 WORDs, so it also saves ~500 WORDs (~1/4 of total memory.)
It should run on your .dsn, but the voltage will be off because I changed the circuit a little.
http://support.melabs.com/DT/DT18x20_Fratello.jpg
I didn't have your code, so the battery icon is different.
Thank You so much ! I will try soon Your hardware ... I must (re) build the PCB.
In Proteus I have some messages ... It's something wrong ?
...and the temperature on display don't follow the variation of sensor(s)-the new temperature is on display NEXT time when the temperature is show !
Oh, OK.
I din't see that your's kept up with changes during each period.
I will fix that.
I wasn't seeing the ADC clock error, but I'll take a look.
Thank You again for helping me !
The code for batterie is this :
...post #16.
Sorry, sometimes I get carried away ... :D
'* Name : DT18x20_Fratello.pbp
'* Author : Darrel Taylor
'* Date : 2/19/2012
'* Version : 1.1 (2/24/2012)
'* Target : 16F684 @ 4 mhz
CLEAR
;----[Main Options]---------------------------------------------------------
TimeToShow CON 5 ; Seconds to show each temperature
;----[Battery Options]------------------------------------------------------
Res1 CON 20000 ; Top Resistor of Voltage Divider
Res2 CON 10000 ; Bottom Resistor of Divider
VDD CON 50 ; VDD voltage
MaxBat CON 140 ; 14.0V ; Batt indicator Max
MinBat CON 98 ; 9.8V ; Batt indicator Min
;----[DS1820 Options]----Value----Default-----------------------------------
DEFINE DS1820_DECIMALS 1 ; 1
DEFINE DS18B20_ONLY YES ; NO
DEFINE DS1820_VERIFYCRC YES ; NO
DEFINE DS1820_USETIMEOUT NO ; YES
MaxRetries CON 4
INCLUDE "DT18x20.pbp" ; Include DT18x20 module
; --- To get the include file, Register at http://darreltaylor.com/whatsup/
Inside VAR PORTC.5 ; Pin assigned to Inside Sensor
Outside VAR PORTC.4 ; Pin assigned to Outside Sensor
;----[Elapsed Timer]--------------------------------------------------------
INCLUDE "Elapsed.bas"
; --- To get the include file ... Go to ...
; --- http://www.pbpgroup.com/modules/wfsection/article.php?article
GOSUB ResetTime
;----[LCD definitions]------------------------------------------------------
DEFINE LCD_DREG PORTC ; LCD Data port
DEFINE LCD_DBIT 0 ; starting Data bit (0 or 4)
DEFINE LCD_EREG PORTA ; LCD Enable port
DEFINE LCD_EBIT 2 ; Enable bit
DEFINE LCD_RSREG PORTA ; LCD Register Select port
DEFINE LCD_RSBIT 1 ; Register Select bit
DEFINE LCD_BITS 4 ; LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ; number of lines on LCD
DEFINE LCD_COMMANDUS 2000 ; Command delay time in us
DEFINE LCD_DATAUS 50 ; Data delay time in us
;----[Analog options]-------------------------------------------------------
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3
ADCON0.7=1 ; Right Justify A/D results
;----[Program Variables]----------------------------------------------------
BattLevel VAR BYTE ; 0 - 10, 0=Empty 10=Full
RawBattery VAR WORD
Volts VAR WORD
LastVolts VAR WORD : LastVolts=0
Sensor VAR BIT : Sensor=1
Char VAR BYTE
y VAR BYTE
Retries VAR BYTE
TempW VAR WORD
GIE VAR INTCON.7
;----[Initialization]-------------------------------------------------------
CMCON0=7 ; disable Comparators
ANSEL=0 ; All Digital
ADCON1=$30 ; ADC_CLOCK is FRC
LCDOUT $FE,1:PAUSE 250:LCDOUT $FE,1 ' Initialize LCD
LCDOUT " TERMO- ",$FE,$C0," VOLT "
GOSUB StartConversions ; get the first reading started
PAUSE 4000
GOSUB StartTimer ; Start the Elapsed Timer
Seconds=TimeToShow ; Force 1st display on start-up
SecondsChanged=1
;----[Main Program Loop]----------------------------------------------------
IF SecondsChanged THEN
SecondsChanged=0
IF Seconds !=0 AND Seconds != TimeToShow THEN GOSUB StartConversions
IF Seconds=TimeToShow THEN ; on each period
Seconds=0
Sensor=!Sensor ; Toggle sensors
LCDOUT $FE,$80
IF Sensor=0 THEN
LCDOUT "I: " ; Indicate Inside sensor
LCDOUT "O: " ; Indicate Outside sensor
IF Sensor=0 THEN
@ DS1820_Select _Inside ; Select Inside DS18x20 pin
@ DS1820_Select _Outside ; Select Outside DS18x20 pin
DS1820_Flags=0 ; clear flags before Stat
GIE=0 ; disable interrupts
@ DS1820_Stat ; get sensor status
GIE=1 ; enable interrupts
IF DS1820_Done THEN ; if conversion finished
@ DS1820_Read ; try to read the temp
Retries=0
RetryRead:
IF DS1820_Error=0 THEN ; if there were no errors
GOSUB TempToLCD ; display TempC
ELSE ;--- Error reading Sensor --------
IF Retries < MaxRetries THEN
Retries=Retries + 1
@ DS1820_Read ; try to read it again (no Conv)
GOTO RetryRead
LCDOUT $FE,$82,"Error "
GOSUB ReadVoltage
PAUSE 100
GOTO Main
;----[Start conversion on both sensors]-------------------------------------
StartConversions:
@ DS1820_Convert ; start conversion
;----[Display TempC on LCD]-------------------------------------------------
TempToLCD:
TempW=TempC
LCDOUT $FE,$82
IF ABS(TempW)/DS1820_DIG < 10 THEN LCDOUT " "
IF TempW.15 THEN
LCDOUT "-" ; if negative, display minus sign
LCDOUT "+"
TempW=ABS(TempW) ; get the positive value
LCDOUT DEC TempW/DS1820_DIG ; Display the Integer portion
LCDOUT "." ; display decimal point
TempW=TempW//DS1820_DIG ; get decimal portion
LCDOUT DEC1 TempW DIG 0
IF ABS(TempC) < 1000 THEN
LCDOUT $DF
;----[Read battery voltage]-------------------------------------------------
RT CON Res1 + Res2 ; Total Divider Resistance
ReadVoltage:
ADCIN 3, RawBattery
Volts=RawBattery * Rt
Volts=DIV32 Res2
Volts=Volts * VDD
Volts=DIV32 1023
IF Volts != LastVolts THEN
LastVolts=Volts
LCDOUT $FE,$C1
IF Volts/10 < 10 THEN LCDOUT " "
LCDOUT " ",DEC Volts/10,",",DEC1 Volts Dig 0," V"
IF Volts >= MaxBat THEN
BattLevel=12
IF Volts <= MinBat THEN
BattLevel=0
BattLevel=(Volts - MinBat +1) * 12 / (MaxBat - MinBat +1)
GOSUB ShowBattery
;----[Show Battery Icon 0 - 12, 0=Empty 12=Full]--------------------------
ShowBattery:
lcdout $FE,$C0,1,$FE,$48,$0A,$1F
for y=4 to 1 step -1
if BattLevel >= (y * 3) then
Char=$1F
if BattLevel >= (y * 3 - 1) then
Char=$17
if BattLevel >= (y * 3 - 2) then
Char=$13
Char=$11
lcdout Char
next y
lcdout $1F
A GREAT piece of code ! A VERRY GOOD EXAMPLE !!!
As usual, I'm speechless...Thank YOU, Mr. Darrel !
:applause:
Bad post, sorry...
but I can' compile the code : "Cannot open file (Include file "P16F684.inc" not found)" ?!
I am so sorry ... :( ....
What a dumb I am ...
Of course, Mr. Darrel have the answer : http://www.picbasic.co.uk/forum/show...2195#post52195
Everything works just fine !
2 Attachment(s)
Everything works just fine ! Thanks again, Mr.Darrel !
One last (I hope :) ) request : Can this "lint" be removed ? I try to find another value for "LCDOUT $nn", but without good results ...
Thanks !
Two ways ...
1) Add a 0 to the last LCDOUT ...2) You can make the battery icon 1 pixel taller ...
BattLevel = (Volts - MinBat +1) * 15 / (MaxBat - MinBat +1)
GOSUB ShowBattery
;----[Show Battery Icon 0 - 15, 0=Empty 15=Full]--------------------------
ShowBattery:
for y = 5 to 1 step -1
Char = $1F
Char = $17
Char = $13
Char = $11
lcdout Char
next y
lcdout $1F
Just finish to write my own code, based on previous source (see post #1 ), it's good for me ...BUT ...
Of course, Mr.Darrel solution it's BETTER !
I owe with some thousands of e-beer :) ! Thanks again !
4 Attachment(s)
This is how my car-dashboard will be (this is beta version :) ) ...
The original is in the last picture.
Congratulations! Very good Job!!!
