ASCII HEX Word to Decimal conversion....
Hello,
My program reads a string of ASCII characters via a serial port, such as 07DC. This represents the decimal year (2012).
How do I get the decimal equivalent of 07DC? What i get is decimal 236 on the LCD.
John
INCLUDE "BS1DEFS.BAS"
DEFINE HSER_CLROERR 1 'USART CLEAR OVERFLOW ERROR
DEFINE HSER_TXSTA 24H 'SET USART TX STAUS REG
DEFINE HSER_RCSTA 90H 'SET USART RC STAUS REG
DEFINE HSER_BAUD 9600 'SET USART BAUD RATE
define HSER_SPBRG 25 'SET PIC OSC FOR 9600 BAUD
PRITIM var BYTE (16) 'ALLOCATE 16 BYTES FOR USART RX DATA
YEAR VAR WORD
LCDOUT $FE,1 'CLEAR DISPLAY
MAIN:
GOSUB LCDMAIN
LCDMAIN:
HSEROUT [16,142,171,2,16,3] 'TRANSMIT CMD 8EAB STATUS PACKET
HSERIN [WAIT (56,70,65,66),STR PRITIM\16] 'WAIT FOR 8FAB - STORE PRI/TIM PACKET
YEAR = PRITIM [0] + PRITIM [1] + PRITIM [2] + PRITIM [3]
LCDOUT DEC YEAR
Re: ASCII HEX Word to Decimal conversion....
The way you are displaying the data works, and I have tested it. The data you are receiving must be wrong. Try to display the raw hex data on the LCD to verify what you are receiving.
Hi John,
The statement; YEAR = PRITIM [0] + PRITIM [1] + PRITIM [2] + PRITIM [3}
will yield YEAR = $30 + $37 + $44 + $43 ' ASCII 07DC
This will set YEAR = $EE which equals 238. Are you sure the value you see on the display is 236 ?
YEAR will equal $00EE in memory.
I am not sure if LCDOUT will support sending WORD values.
- Martin
readitaloud
I wasn't sure about that statement, but the LCDOUT part works fine sending the word variable.
Is this all your code? I do not see any LCD defines.
spcw1234
Not sure what you mean by sending the word variable.
John,
You need to convert from ASCII to binary value. 4 bytes become 2 bytes.
Add the following:
' New variables
x var byte
y var byte
i var byte
' ************* ASCII to Binary **************
for i = 0 to 2 step 2
if PRITIM[i] > $40 THEN ' Handle MSNibble.
x = PRITIM[i] + 1
x.3 = 1
x = x << 4
x = PRITIM[i]
x = PRITIM[i] << 4
if pritim[i + 1] > $40 then ' Handle LSNibble.
y = PRITIM[i + 1] + 1
y.3 =1
y = y & %00001111
y = PRITIM[i + 1]
y = y & %00001111
if i = 0 then
YEAR.byte1 = x | y
YEAR.BYTE0 = x | y
next i
'************* END of ASCII to Binary *************
YEAR is now ready to be sent to LCD display.
- Martin
These displays are ASCII. So no need to convert. Try the line below it will send ASCII $32,$30,$31,32 =(2,0,1,2)to the lcd. You may have to reverse the order PRITIM[X]'s ? Depending on the order you receive the data.
LCDOUT $FE, $80, "YEAR =",PRITIM[3],PRITIM[2],PRITIN[1],PRITIM[0]
