I will not get the Aya products where I live
Hi Luciano,
Thanks for the post. I live in Kolkata India and would not be able to source the Aya products. Other design constraint are space and cost. Please let me know if you have any ideas. Whatever it is if I get through the problem rest assured that I will post the schematic and code.
Sougata
I need to measure line to line voltage for a three phase three wire line.
Hi jmgelba,
Thank you for your post. My application is basically a voltage monitor (via RS232) and trip circuit with presettable hysterisis and auto recovery. I would be measuring between R-Y and Y-B. It is the output of a DG and a three phase three wire system. Any idea or suggestions would be greatly appreciated. Thanks in advance.
Best Regards
Sougata
Could you explain a little bit more
Dear Jmgelba,
As for the auto-transformer based scheme could you explain the construction process or help with schematics
Sougata
Hi Saugata,
sorry I hadn't seen this post.
I must tell U that U need to brush up Ur measurement technics although
U are good on programming PIC.
a) Diode rectified output voltage of attenuated mains will be highly
non-linear as U are trying to convert about 1-2 volts signal and diode drop
is typical 0.6 Volts. Simple remedy is :- use diode directly on mains and then
attenuate the DC voltage. This will give somewhat better accuracy.
b) better use a small OPAMP based precision detector. This will give U best
accuracy at very little extra cost.
c) Avoid transformerless power supply. This will help in measuring multiple
inputs. Also instead of measuring RY-YB-BR fashion measure the voltages
at star point (neutral) and corrolate to line voltage. This way U can arrange
voltage divider network in star fashion and measure in cyclic way.
d) U can use Exxar or NS made voltage to frequency converters and transmit the results by optocoupler to RS232. Those have about 1-2% accuracy which is good enough. If U can't get them then send me private
email and I will show U how to get result from even 555 !
regards.
dayama
