Long Distance Input's to Pic
Hi
What's considered good design practice when you have 4 mechanical input switches that are located 8 ft away from the pic? The application is a kit car. I was going to run a shielded cable, or shielded cable with optical isolation. Any suggestions?
Greg
Long distance inputs to Pic
Hi Steve
Thanks for your reply. Could you explain what you mean by "good resistor match and sufficient current on the line + simple noise filter".
I thought you would always use the internal pullup resistors if available, otherwise, a 10K pullup resistor.
Greg
