Cool Sound Effects?
Here's one:
ticksnd:
@ movlw 0x01 'set sound duration for intro
@ movwf _sbyte '
@ movlw 0x1B 'set sound step value for intro
@ movwf _soundcalc 'soundcalc = $1B
@ movlw 0xFF 'set the start frequency
@ movwf _sbuff '
xcr:
@ movf _soundcalc ,W 'calc the next sound
@ addwf _sbuff ,F '
@ call _audo 'make sound
@ decf _sbuff ,F '
@ incfsz _sbuff ,F '
@ goto _xcr 'check for exit blast routine
@ return 'exit when sound is finished
audo:
SOUND portc.7,[sbuff,sbyte] 'output sound
@ return
Just gosub ticksnd.
Anyone got any others to share?
Re: Cool Sound Effects?
Here's one that sounds like a blast from a futuristic laser:
blast: '
soundcalc = $FD : sndcnt = 0 'make blast sound
@ movlw 0x8F 'set the start frequency
@ movwf _sbuff '
xxxxx:
@ incf _sndcnt ,F '
IF sndcnt = $25 THEN return '
@ addwf _sbuff ,F '
@ decf _sbuff ,F '
@ goto _xxxxx 'check for exit blast routine
audo:
@ return
Translation to PBP. :D
SoundPin VAR PORTC.7
Post #1
ticksnd:
sbuff = $FF
WHILE sbuff != 0
sbuff = sbuff + $1B
SOUND SoundPin,[sbuff,1]
WEND
Post #2
blast:
FOR sndcnt = $8F TO $20 STEP -3
SOUND Sound2Pin,[sndcnt,1]
NEXT sndcnt
A little easier on the eyes.
Uht-Oh, I got an idea......
So I'd like to try some of these sound effects... But it seems this thread started out of thin air??? What am I missing? Is this a continuation of another thread? Is there a complete sample code that can be posted.
In the dark here... (though that is nothing new for me)
That is the complete code, you only need to declare the byte sized variables used,
and use the sounds in some program of your own :)
Darrel Taylor
Translation to PBP.
It is always good to have a translator :D.
Here are a couple more sound effects. All of these use the freqout command. I tried them on a PIC18F4550 at 48 mhz. You can listen to them on the attached sound file.
Howler
Howler:
FOR sndcnt = 1 TO 4
FREQOUT sound2pin, 500, 467, 687 ' was combine 1400 Hz and 2060 Hz
FREQOUT Sound2pin, 500, 817, 867 ' was combine 2450 Hz and 2600 Hz
NEXT sndcnt
Space Transporter
Space_Transporter:
'DEBUG "Space Transporter", CR
FOR sndcnt = 5 TO 5000 STEP 5 ' frequency sweep up
FREQOUT sound2pin, 15, sndcnt, sndcnt */ 323 ' play note, note * 1.26
NEXT sndcnt
FOR sndcnt = 5000 TO 5 STEP -5 ' frequency sweep down
FREQOUT sound2pin, 15, sndcnt;, sndcnt */ 323 ' play note, note * 1.26
NEXT sndcnt
Warp
Warp:
for sndcnt2 = 200 to 450 step 1
FREQOUT Sound2pin,7,sndcnt2;,(sndcnt2 -166)
next sndcnt2
warble/alarm sinusoidal - could use some work
sineval var byte[32]
sineval[0] = 128
sineval[1] = 148
sineval[2] = 167
sineval[3] = 185
sineval[4] = 200
sineval[5] = 213
sineval[6] = 222
sineval[7] = 228
sineval[8] = 230
sineval[9] = 228
sineval[10] = 222
sineval[11] = 213
sineval[12] = 200
sineval[13] = 185
sineval[14] = 167
sineval[15] = 148
sineval[16] = 128
sineval[17] = 108
sineval[18] = 189
sineval[19] = 171
sineval[20] = 156
sineval[21] = 143
sineval[22] = 134
sineval[23] = 128
sineval[24] = 126
sineval[25] = 128
sineval[26] = 134
sineval[27] = 143
sineval[28] = 156
sineval[29] = 171
sineval[30] = 189
sineval[31] = 208
warble: ;alarmish sinusoidal - needs some work!
for sbuff = 1 to 10
for sndcnt2 = 0 to 31 step 1
FREQOUT Sound2pin,7,(500 +sineval[sndcnt2]);,(sndcnt2 -166)
next sndcnt2
next sbuff
Nice :)
___________________
