Re: LCD cable length? > 40 feet.
Here's Darrel with 25 feet of ribbon cable connected to his: http://www.picbasic.co.uk/forum/show...7417#post47417
Edit: Wildbilly ran it with 40 feet. A few posts later.
Thanks guys :)
Didn't want to do the wiring, but should have at least searched!
It's a VFD display with the standard LCD controller.
http://img.photobucket.com/albums/v1...hicle_Comp.jpg
It's working with one metre of cable, but a bit hit & miss.
No garbled text, but sometimes it doesn't come on at all.
Maybe it just needed a longer startup time than the usual PAUSE 1000.
Ideally, I want about five metres of cable length, so I'll keep reading!
In the thread where we ran them on 25/40ft cables, the LCDOUT library routines were over-ridden so the timing could be changed.
Normally, the LCDOUT command gives a 1uS pulse on the enable line.
But as the cable gets longer, 1uS isn't enough.
I used 5uS for the 25 ft length, which seemed to overcome the rounding off of the waveform on a scope.
You might try using the routines from that thread with the modified timing.
Essentially, it's the LCD_AnyPin routines with a few modifications.
Will do, thanks :)
I think I'll have to.
A little problem...
Installed the hijack routines and the two files in PBP directory.
When I use the include file for lcdanypin, I get an error (using MPASM)
for line 87 which is this line:
LOW LCD_RS : HIGH LCD_E
If I comment that out I then get a lot of errors
LCD_RS and LCD_E should be declared in your program, along with the other LCD pins.
Something like ...
;----[ Change these to match your LCD ]---------------------------------------
LCD_DB4 VAR PORTA.0
LCD_DB5 VAR PORTB.3
LCD_DB6 VAR PORTB.7
LCD_DB7 VAR PORTC.1
LCD_RS VAR PORTD.4
LCD_E VAR PORTA.1
LCD_Lines CON 2 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
LCD_DATAUS CON 50 ' Data delay time in us
LCD_COMMANDUS CON 2000 ' Command delay time in us
INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
Bah! Still not having much luck here,
I have the LCD routines working, and changed the LCD_anypin file as follows:
;===============( DO NOT Change anything below this line )====================
;----[Virtual LCD Port --- 4bit mode]-----------------------------------------
LCD_Port_HNIB macro ; Port definition for LCD High Nibble
Vbit LCDCDFLAG, _LCD_RS ; Select Command/Data register
Vpin 4, _LCD_DB4 ; Put the High Nibble on the bus
Vpin 5, _LCD_DB5
Vpin 6, _LCD_DB6
Vpin 7, _LCD_DB7
PulseLow _LCD_E, 5 ; pulse the Enable Pin for 2 us
LCD_Port_LNIB macro ; Port definition for LCD Low Nibble
Vpin 0, _LCD_DB4 ; Put the Low Nibble on the bus
Vpin 1, _LCD_DB5
Vpin 2, _LCD_DB6
Vpin 3, _LCD_DB7
Since I'm only using a single display, hopefully that's all that is needed to enable the E pin for 5us.
Still the display coming on at all after startup is hit & miss.
It seems to come on straight after programming with the pickit2 (when powered by the pickit2,
but doesn't want to come on when powered by any other means (or even by the pickit2 when not being programmed).
