I need help on ADC interrupt
Hi everyone, I have a working code that receives numbers 1-3 from a cellphone (Bluetooth enabled)
clear
DEFINE OSC 20
pause 4000
Include "modedefs.bas"
B0 Var Byte
TRISD = %00000000
TRISC = %10000000'set TX (PORTC.6) to out, rest in
TRISB = %0111101 ' Set PORTB.0-2 (LEDs) to output, 3-6 to input
PortB = 0
PortD = %00000000
' send command to Bluetooth(IP, name)
SerOut2 PortC.6,84, [$02,$52,$27,$06,$00,$7F,$12,$13,$23,$17,$09,$00,$03]
pause 200
SerOut2 PortC.6,84, [$02,$52,$66,$00,$00,$B8,$03]
pause 200
Serout2 PortC.6,84, [$02,$52,$04,$11,$00,$67,$10,$4D,$49,$43,$52,$4F,$42,$4F,$58,$42,$54,$31,$20,$20,$20,$20,$00,$03]
RX var byte ' Receive byte
'@ DEVICE HS_OSC
Define ADC_BITS 8 ' Set number of bits in result
adval1 Var Byte ' Create adval to store result
adval2 Var Byte
adval3 Var Byte
ADCON1 = %00000010 ' Set PORTA analog
TRISD = %00000000
led0 var PORTD.3
led1 var PORTD.4
cnt var byte
OPTION_REG = $7f ' Enable PORTB pull-ups
TRISB = %00000000 ' Set PORTB.0-2 (LEDs) to output, 3-7 to input
PortB = 0
serout PortD.2,T9600,[$1B,$45]
serout PortD.2,T9600,["Loging on.."]
pause 300
Menu:
'****** [Menu setup on PC screen] *************************
serout PortD.2,T9600,[$1B,$45,"**System Ready**"]
serout PortD.2,T9600,[$D,"GSTS week"]
Receive:
' ***** [Receive the menu selection from PC] ***************
serin PortC.7, T9600, RX 'Receive menu from PC
serout PortD.2,T9600,[$1B,$45,RX]
RX = RX - $30 'Convert ASCII to decimal value
If RX > 3 then Error ' Test for good value
Branch RX, [zero, one, two, Three] 'redirect to menu selection code
error:
serout PortD.2,T9600,[$1B,$45,"Try again"]
goto menu
Zero:
'***** [ Code for zero value ] *****************************
goto menu 'Return to menu, zero is not a valid selection
One:
'***** [Code for selection 1] ************************
Toggle PortB.0
serout PortD.2,T9600,[$D,"Toggle L1"]
goto menu 'Return to main menu
Two:
Toggle PortB.1
serout PortD.2,T9600,[$D,"Toggle L2"]
Three:
Toggle PortB.2
serout PortD.2,T9600,[$D,"Toggle L3"]
I'm trying to add the following codes
ADCIN 0, adval1 ' Read channel 0 to adval D1
ADCIN 1, adval2 ' Read channel 0 to adval D0
if adval1 >25 then
SerOut2 PortC.6,84, ["1"]
Serout PortD.0,T9600, [$1B,$45,"[1] ",#adval1]
Pause 100
Endif
if adval2 >25 then
SerOut2 PortC.6,84, ["2"]
Serout PortD.0,T9600, [$1B,$45,"[2] ",#adval1]
Pause 100
Endif
The above codes works in a different application, this triggers when an RF data is received on A0 and A1..and now I'm trying to combine this code in the above code. I tried merging the two codes but it seems the RF codes does not response when triggering the RF transmitter. Do you think I need to apply an interrupt? Can you anyone guide me how?
Thanks in advance,
tacbanon
Re: I need help on ADC interrupt
Check the data sheet for the MCU you are using, you do not say which one.
Something does not look correct.
Hi macrackit,
Sorry for that my mistake...here is the whole code, I'm using Pic16F877A with 20mhz crystal
clear
INCLUDE "MODEDEFS.BAS" ' Include Shiftin/out modes
pause 4000
'@ DEVICE HS_OSC
DEFINE OSC 20
adval2 Var Byte
adval3 Var Byte
TRISA = 111111 ' Set PORTA to all input
ADCON1 = 000010 ' Set PORTA analog
TRISC = 000000 ' PORTC.7 is the RX input, PORTC.6 is the TX output
TRISD = 000000
led0 var PORTD.0
led1 var PORTD.1
' The following codes is for bluetooth------------------------------------------------------------------------------------
pause 200
pause 200
mainloop:
ADCIN 0, adval1 ' Read channel 0 to adval1
ADCIN 1, adval2 ' Read channel 1 to adval2
pause 20
Pause 100 ' Wait .1 second
if adval1 >25 then
SerOut2 PortC.6,84, ["1"] ' sends 1 to Bluetooth TX
Serout PortD.2,T9600, [$1B,$45,"[1] ",#adval1] ' Displays to serial LCD for debugging
Pause 100
Endif
if adval2 >25 then
SerOut2 PortC.6,84, ["2"] ' sends 2 to Bluetooth TX
Serout PortD.2,T9600, [$1B,$45,"[2] ",#adval2] ' Displays to serial LCD for debugging
Pause 100
Endif
Goto mainloop ' Do it forever
My problem is how to receive incoming data from bluetooth with SERIN without freezing the application..
regards,
tacbanon
I'm trying to play with this code from Mister_e, but my trouble is I can not send message to PC at the same time(Sending Hello and reading from analog pin). I hope anyone can give a hint on this.
' Simple program to handle USART interrupt using PIC16F877 @20MHZ
' This program will Blink a LED on PORTB.0 to show
' that the PIC is running.
' This program also allow the user to activate or deactivate
' a LED connected on PORTB.1 pin by sending command from a PC
' terminal software using 9600,n,8,1 setting
' User command:
' 1. If character "1" is received => enable the LED1
' 2. if character "2" is received => disable the LED1
' 3. If character "3" is received => enable the LED2
' 4. if character "4" is received => disable the LED2
'DEFINE LOADER_USED 1 ' using bootloader
DEFINE OSC 20 ' running at 20 MHZ
' PORT setting
TRISC=%10000000 ' RC.7 => USART RX pin set to input
' all other pin set to output
TRISB=0 ' RB<7:0> set to output
' USART setting
' Since we will not use HSERIN/HSEROUT, we must
' write directly to internal PIC register
TXSTA=$24 ' enable transmit and SPBRGH=1
RCSTA=$90 ' Enable USART and continuous receive
SPBRG=129 ' BAUD RATE = 9600 BAUDS
' Interrupt definition
PIE1.5 =1 ' enable USART receive interrupt
INTCON.6 =1 ' enable peripheral interrupt
' Alias definition
RCIF var PIR1.5 ' receiver interrupt
StatusLED var PORTB.0 ' the LED who show a 'running process'
UserLED1 var PORTB.1 ' the LED1 that user want to control
UserLED2 var PORTB.2 ' the LED2 that user want to control
UserLED3 var PORTB.3 ' the LED3 that user want to control
UserLED4 var PORTB.4 ' the LED4 that user want to control
' Variable definition
Delay var word '
DataIn var byte ' use to store RCREG content
Discard var byte ' use to erase RCREG register
' Hardware/software initialisation
PORTB=0 ' clear PORTB
on interrupt goto USARTInterrupt
DEFINE ADC_BITS 8 ' Set A/D for 8-bit operation
DEFINE ADC_CLOCK 1 ' Set A/D clock Fosc/8
DEFINE ADC_SAMPLEUS 50 ' Set A/D sampling time @ 50 uS
adval Var Byte ' Create adval to store result
'ADCON1 = %00000011 ' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
Start:
' Main program loop that make the user happy to
' see a LED flashing to mean that something is
' running
Serout2 PortC.6, 84,["Hello",13]
toggle statusled
'for delay = 1 to 5000 ' use a loop delay to ensure
'pauseus 5 ' getting interrupt as fast as possible
'next
ADCIN 0, adval
Serout2 PORTC.6, 84, ["Value: ", DEC adval, 13, 10] ' Display value
goto start
disable interrupt
USARTInterrupt:
' Here's the interrupt routine who will make the user
' much happy by giving him the feeling to have the
' control on the machine when the status of the user
' LED will change
RCSTA=0 ' Disable serial port AND
' clear possible error (FERR,OERR)
datain=RCREG ' Get data
while RCif ' wait untill the RCREG is empty
discard=RCREG ' by reading it and store result in a
wend ' don't care variable
select case datain ' What to do with that data???
case "1" ' User selection = 1
userled1=1 ' => Enable the LED
case "2" ' User selection =2
userled1=0 ' => disable the LED
case "3" ' User selection = 3
userled2=1 ' => Enable the LED
case "4" ' User selection =4
userled2=0 ' => disable the LED
case "5" ' User selection = 3
userled3=1 ' => Enable the LED
case "6" ' User selection =4
userled3=0 ' => disable the LED
case "7" ' User selection = 3
userled4=1 ' => Enable the LED
case "8" ' User selection =4
userled4=0 ' => disable the LED
end select
RCSTA=$90 ' Re-enable the serial PORT AND
resume ' get out of here
enable interrupt
Hardware: Pic16F877A at 20Mhz crystal
regards,
tacbanon
I managed to send message to PC and added sensor reading(working in a separate program), but now I have strange reading on my temperature and light sensors. kindly check my code.
' PORT setting
' USART setting
' Alias definition
Delay var word '
'ADCON1 = %00000010 ' Set PORTA analog
'--------Variables--------------------------------------------------------------
light var WORD
samples VAR WORD ' Multiple A/D sample accumulator
sample VAR BYTE ' Holds number of samples to take
temp VAR BYTE ' Temperature storage
samples = 0 ' Clear samples accumulator on power-up
samples2 var word
sample2 VAR BYTE
samples2 = 0
Start:
' running
toggle statusled
Pause 100
FOR sample = 1 TO 20 ' Take 20 samples
ADCIN 1, temp ' Read channel 0 into temp variable
samples = samples + temp ' Accumulate 20 samples
PAUSE 100 ' Wait approximately 1/4 seconds per loop
NEXT sample
temp = (samples/20)
Hserout ["Temp=",DEC temp ,"'C" ,13]
ADCIN 0, light
Hserout ["Light=",DEC light ,13]
goto start
disable interrupt
USARTInterrupt:
' LED will change
end select
enable interrupt
regards,
tacbanon
I finally got the code to work, the problem was faulty circuitry, sorry for not double checking on my part before posting...Thank God for this forum and everyone here who I believed to be my PICexperts(macrackit, Mr_e, DT, Skimask, Henrick just to name a few) heroes...:)
Merry Christmas everyone!!!!
regards,
Tacbanon
